HDMI-DVI
(05-24-2016, 09:58 AM)Luke Wrote: Could you please check if you can SSH into the Pine ? its good that the red LED stays solid
Luke, if you're in »Let's figure out if this board is DOA or not!« mode then it would be helpful if you would suggest the correct steps (eg. »use not a crappy but a good Linux OS image -- the Xenial from longsleep --, connect Ethernet and watch for LED activity on the Ethernet jack«). But if you would read through the threads you reply to all the time you would realize that he figured already out what's wrong: Just his display not being able to show anything since it can't cope with 1080p obviously (read the first post to understand) while Pine64 works flawlessly on the large TV.
So instead of wasting your and others time it would be an idea to adopt the information already known (in the various threads where so much knowledge is available that none of the 'responsible' people starts to collect -- the laughable pine64.pro FAQs are still blank pages and the official FAQ is still solely marketing chit chat) and also adopt the information provided in the threads you reply to?
@aminhb: In case you want to use Linux then check whether your display supports any of the following resolutions:
480i
576i
480p
576p
720p50
720p60
1080i50
1080i60
1080p24
1080p50
1080p60
If yes, you can set this in uEnv.txt, if not your display won't negotiate a display. No idea about Android/RemixOS -- here you are dependent on 'official' information since Android development happens in a closed manner (unlike Linux where community develops in the open)
BTW: 'DVI display' always sounds like ancient displays with 4:3 aspect ratio. Read from here on what to expect: http://forum.pine64.org/showthread.php?t...72#pid8772
HDMI-DVI - by aminhb - 05-23-2016, 08:40 AM
RE: HDMI-DVI - by Luke - 05-23-2016, 09:59 AM
RE: HDMI-DVI - by aminhb - 05-24-2016, 09:24 AM
RE: HDMI-DVI - by Luke - 05-24-2016, 09:58 AM
RE: HDMI-DVI - by tkaiser - 05-24-2016, 10:35 AM
RE: HDMI-DVI - by aegrotatio - 06-08-2016, 08:20 PM
RE: HDMI-DVI - by aminhb - 06-10-2016, 06:24 PM
RE: HDMI-DVI - by tllim - 05-23-2016, 11:55 AM
RE: HDMI-DVI - by lenny.raposo-pine64.pro - 05-24-2016, 10:47 AM
RE: HDMI-DVI - by torusJKL - 05-24-2016, 04:56 PM
RE: HDMI-DVI - by aegrotatio - 01-07-2017, 11:57 PM
RE: HDMI-DVI - by Luke - 01-08-2017, 10:52 AM
Sad HDMI to DVI Color issues? leatherlips 5 15,198 10-09-2017, 05:57 AM
Last Post: Luke
  Would HDMI screen for Raspberry PI work? dhewko 1 3,445 07-23-2017, 06:43 AM
Last Post: MarkHaysHarris777
Exclamation HDMI 1024 x 600 mus1c 4 6,226 01-09-2017, 07:30 AM
Last Post: mus1c
  HDMI issues rahlquist 35 45,310 12-24-2016, 02:20 AM
Last Post: sboyce
  Monitor no output (through HDMI to DVI adaptor) gam01hr 10 14,843 11-15-2016, 01:46 PM
Last Post: Armbian User
  HDMI CEC ayufan 15 19,549 09-08-2016, 10:24 AM
Last Post: ayufan
  HDMI to VGA adapter for Android PineA64 tech support setup MarkHaysHarris777 0 2,402 08-06-2016, 12:47 PM
  hdmi_group CEA or DMT hdmi group specify uEnv.txt MarkHaysHarris777 2 4,986 07-01-2016, 08:23 AM
  No CEC over HDMI? utdrmac 2 5,612 03-07-2016, 03:05 PM
Last Post: utdrmac
  HDMI 3D, ARC + Ethernet Channels? bigmacattack 4 12,002 01-29-2016, 06:29 PM
Last Post: StefanB
