sudo / lock screen password keeps resetting to default
This is the second time I have installed mobian on the eMMc of my Pinephone UBPorts Edition.
The first time I changed the password from the default "1234" using the terminal emulator with the
command "sudo passwd" and it worked.
However, after making some annoying changes I couldnt revert, I decided to reinstall everything and now,
when I try to change the password in the terminal emulator using the same command "sudo passwd", it says:
passwd: password updated successfully
But, when I lock the screen and then attempt to unlock it with the new password. It doesnt work.
When I try with the default "1234" password it works like if I had never changed it "successfully".
Not sure what is happening or what Im doing wrong, maybe Im just tired. Any ideas?
sudo / lock screen password keeps resetting to default - by ergo owl - 09-03-2020, 04:11 AM
  Screen auto-rotation sensitivity mdk 0 286 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 669 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,305 06-22-2023, 11:20 AM
Last Post: Melechtna
  4G data on default startup / boot dcinoz 1 859 04-29-2023, 11:24 PM
Last Post: dcinoz
  Bogus default gateway keeps appearing Zebulon Walton 7 2,272 02-25-2023, 09:48 PM
  Lock screen question: always squeekboard tuxcall 1 1,249 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,026 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,557 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,865 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,263 07-18-2022, 03:29 AM
Last Post: vusra
