Possible to upgrade PBP with NVMe M.2 1TB SSD from Sabrent?
(08-17-2020, 06:25 PM)lot378 Wrote: Thanks and understood. From the Sabrent site, the only power state information for that drive is 6.6/5.3W (unsure what the two figures mean). The PBP has a power issue with the NVMe adapter it can reliably supply 2.5W continuous and 8.25W peak momentary. When you were copying the installation to the NVMe and got the panic message, it may well have been caused by the power draw. It may be possible to work around it by setting/restricting it to a lower power state.
From the Sabrent site, information in the table at the bottom of the page:
https://www.sabrent.com/product/SB-ROCKE...escription
For power limitations see:
https://wiki.pine64.org/index.php?title=...Me_adapter
For how to use the nvme-cli package and nvme command see:
The second section of the wiki contains a link to the NVMe compatability listing.
The nvme command will show you the power usage in each power state.
The cp command that you used was ok.
If you can look at the above wiki sections, read the manual for the nvme command then try to fetch the power states that would be useful info for us to see. Then we can help you to make some sort of judgement about changing the power state before trying the copy again. In the end, it would be good to update the compatibility listing with your drive (it's not there at the moment) with a good/bad and what steps were needed. But first things first, let's see a listing of the power states please.
Okay I will try to procure the nvme power status as soon as I get the chance, thanks!
RE: Possible to upgrade PBP with NVMe M.2 1TB SSD from Sabrent? - by kkdao - 08-19-2020, 10:37 AM
  New Working nVME gilwood 0 258 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,593 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,864 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,600 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,951 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,893 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,962 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,671 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,877 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 32,507 02-09-2021, 11:32 PM
Last Post: dsimic
