Activating a sim card
(08-05-2020, 06:23 PM)bcnaz Wrote: I tried to activate a new un-activated AT&T PrePaid sim card in my Brave Heart phone with Mobian running on it without succeeding.
 The phone does see the new AT&T sim,  but it will not dial out to the 611 number to activate.
The B.H. phone does function with a sim card I removed from my Android phone.
 But,
         The Android sim card does have a problem with data,
> an AT&T tech had previously suggested replacing that sim card when I called AT&T to fix the Android phone.
So I was hoping I could just activate a new sim card in my BH Pine phone directly.
Apparently Android has an app that makes it possible to activate the sim card.?
Is there an app I can put on Debian to activate a new sim card, or should I activate the card in the old Android phone, then move it to my Pine phone..?
Thanks,  B.C.
Your best bet might be activating the guarunteed to work old Android phone. After the SIM card works successfully on that, transfer that SIM card into the Pinephone and boot it up. Myself I used a working AT&T SIM card which I had switched multiple times on different Android cell phones.
I have heard of users on this forum talking to the *right* AT&T representative and giving them the IMEI directly from the Pinephone for activation directly. If you try this make sure to make clear you know it is a compatible phone for AT&T. Some less educated employees might say "it's not on their list" but they should have no problem activating with the IMEI if they know what they are doing.
There is a webpage for activating SIM cards for AT&T. You could try that and input the pinephone imei number while selecting a phone on their list.
Knowing there could be problems depending on the staff member, might be easier to activate that Android and transfer it over to make it go as smooth as possible.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
Activating a sim card - by bcnaz - 08-05-2020, 06:23 PM
RE: Activating a sim card - by LazLong - 08-05-2020, 07:08 PM
RE: Activating a sim card - by bcnaz - 08-05-2020, 07:32 PM
RE: Activating a sim card - by RTP - 08-08-2020, 01:20 PM
RE: Activating a sim card - by bcnaz - 08-08-2020, 06:37 PM
  APN settings not working with new operator SIM card user641 1 1,081 03-01-2023, 04:43 PM
Last Post: anonymous
  What does handle SD card automount? mdk 1 1,085 01-29-2023, 03:15 AM
Last Post: mdk
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 1,799 07-16-2022, 02:28 PM
Last Post: dachalife
  Apps and SD Card biketool 2 1,950 03-06-2022, 09:47 AM
  How to flash a µSD-Card with Balena Etcher walter1950 1 1,358 01-22-2022, 02:06 AM
Last Post: bcnaz
  How to insert a SIM-Card and/or a µSD-Card walter1950 0 956 01-21-2022, 02:46 PM
Last Post: walter1950
  When I set SD card as /home, PP can't complete boot nelstomlinson 4 2,932 12-27-2021, 03:06 PM
Last Post: nelstomlinson
  Persistently mount SD card? DarkManiels 5 5,779 11-21-2020, 08:28 PM
Last Post: HLing
  weird SIM card question RodneyMyers 4 4,910 10-16-2020, 01:47 PM
Last Post: ThrillGates
  How to mount an SD card? gizmuth 4 5,769 07-15-2020, 06:41 AM
Last Post: a-wai
