Bricked phone after u-boot update
Hi there - I'm hoping someone can help me figure out how to fix my Mobian installation. I've got it installed on the eMMC, with a 128Gb SD card for storage of music and such, and it's been working great since I got the phone several weeks ago. Today I did a couple of apt update & upgrades. On the second update it told me that u-boot-sunxi and u-boot-tools were among the packages to be updated. I ran sudo apt upgrade as usual to upgrade the other packages in the list, but then following the directions on the Mobian wiki Tweaks page I also ran
sudo u-boot-install-pinephone
to actually upgrade u-boot. The output in the terminal was exactly the same as the last bit of output from my regular sudo apt upgrade, so I don't know if this actually did anything different or not.
I then tried to reboot the phone, since I figured this would be good after updating the bootloader, and after it shut down nothing happened. Now whether I push the power button briefly or for 5 seconds or so I can't get the phone to turn on - the screen remains blank and off. No green LED, nothing. I swapped out my SD card for a Jumpdrive card and am able to get in and see my filesystem just fine. But when I remove the Jumpdrive SD again I still can't boot into Mobian.
Any thoughts on how to be able to boot into Mobian again would be much appreciated. I'm assuming with Jumpdrive I can do something to fix it, but am not familiar enough with the boot file system to know what files to replace or commands to run. Thanks!
Bricked phone after u-boot update - by DarkManiels - 08-04-2020, 08:00 PM
RE: Bricked phone after u-boot update - by Boern - 08-04-2020, 11:23 PM
RE: Bricked phone after u-boot update - by Boern - 08-07-2020, 11:48 AM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,052 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 979 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,023 07-09-2023, 08:57 PM
Last Post: vusra
  4G data on default startup / boot dcinoz 1 856 04-29-2023, 11:24 PM
Last Post: dcinoz
  Wifi doesn't work after update nickolas 2 1,267 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,360 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 983 03-06-2023, 12:06 PM
Last Post: freelectro
Exclamation Impossible to login since the latest update anonymous 12 4,332 02-26-2023, 01:01 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 4,072 02-13-2023, 02:11 AM
Last Post: sharase
