My PBP does not power on at all
I've managed to resurrect my Pinebook Pro! Of course, from SD.
Analyzing all the suggestions that you have made me, and looking for other forums related to the Pinebook Pro, I discovered that some users had failed to load it with the USB-C cable. I remembered that, just before my PBP died, I had recharged it through that system. This possibility I had previously ruled out because, afterwards, once the PBP no longer turned on, I had recharged it with the normal cable several times. unsuccessfully. However, I read that a user had managed to bring the laptop back to life after recharging it overnight with the normal cable, and decided to try the same. I plugged it into the wall socket and, more than twelve hours later, it finally turned on.
What I still do not understand is why the PBP did not turn on when, previously, I disconnected the battery and bypassed the wires to work with AC ...
It appears that what appeared to be a software bug is actually a hardware problem with the USB-C
My PBP does not power on at all - by prokofiev - 07-03-2020, 06:41 AM
RE: My PBP does not power on at all - by xmixahlx - 07-03-2020, 09:37 AM
RE: My PBP does not power on at all - by xmixahlx - 07-03-2020, 10:49 PM
RE: My PBP does not power on at all - by bcnaz - 07-04-2020, 04:56 AM
RE: My PBP does not power on at all - by bcnaz - 07-04-2020, 01:27 PM
RE: My PBP does not power on at all - by prokofiev - 07-12-2020, 03:27 AM
  Lockable-until-power-cycle persistent storage Melab 0 738 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 854 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 642 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,274 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,324 09-09-2022, 08:13 PM
  Replacement Power Cord recommendation? nathanielwheeler 3 3,341 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 1,824 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 4,931 11-30-2020, 10:57 PM
Last Post: rimaille
  Power consumption and suspend to ram robt 33 43,332 11-30-2020, 04:32 PM
Exclamation Seemingly lost power permanently now /cry jimsurvak 2 3,114 11-16-2020, 06:22 PM
Last Post: jimsurvak
