Fixing audio after deep sleep: Work Thread
I found the actual guide to registers and such for the es8316 (vs just the datasheet).  Attached.
There is also this thread: https://forum.pine64.org/showthread.php?tid=10268
It has the unbind/bind command that seems to re-initialize the driver without re-inserting modules, though it is apparently somewhat at risk of a kernel panic if sound is playing.
$ sudo tee /sys/bus/i2c/drivers/es8316/{un,}bind <<< 1-0011
This should be useful to trace flow through as well.
.pdf   es8316_user_guide.pdf (Size: 813.69 KB / Downloads: 1,216)
RE: Fixing audio after deep sleep: Work Thread - by Syonyk - 06-29-2020, 08:55 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 905 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Sleep and external display - Are there any options? chris88233 7 1,735 09-04-2023, 09:03 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,285 08-31-2023, 04:20 PM
Last Post: TRS-80
  Audio on Armbian Hobbes42 1 848 08-04-2023, 01:18 AM
Last Post: Humid Stylus
  Audio Driver on the pbp korreckj328 5 1,690 05-01-2023, 12:58 PM
Last Post: korreckj328
  With the help of a friend, I installed a beautiful deep os distribution, but I won't wangyukunshan 0 605 03-03-2023, 10:56 PM
Last Post: wangyukunshan
  Any chance of fixing the audio issues on the new batch PBP(it can't be just me...) crazyquark 0 764 09-30-2022, 10:15 AM
Last Post: crazyquark
  manjaro on pinebook pro low audio quality over jack alcck 1 1,077 09-22-2022, 11:31 AM
Last Post: petersen77
  No audio on Pinebook Pro with Fedora? foobar 1 1,414 08-22-2022, 12:12 PM
Last Post: snorwood
  How to make manjaro sleep or hibernate? KDE? regretfulpineuser 0 987 06-20-2022, 12:56 AM
Last Post: regretfulpineuser
