Signal Desktop Builds for Manjaro aarch64
Evening, Pine64 community.
I've been doing builds of the Signal Desktop client for Manjaro/aarch64 for myself for a while now.  They've proven stable enough for my daily use that I've decided to start posting them here in case anybody else can benefit from them.
I'll try to keep this post updated within a couple of weeks of new releases.  This is a best-effort project and the packages are distributed as-is, without any warranty, express or implied, including the implied warranties of merchantability and fitness for a particular purpose, etc. etc. etc. ad nauseam.  These are NOT official Signal builds, and I am not in any way affiliated with the Signal project or Open Whisper Systems.  TL;DR use at your own risk.  Distributed under the GPLv3, source code and detailed license are available at https://github.com/signalapp/Signal-Desktop
These are Manjaro/aarch64 packages.  Install with pacman -U directly, or create a local repo for use with pacman -S, whichever suits you.
Current stable versions (Google Drive download links)
Notes
  • Minor modifications to some of the build scripts may be required, and often vary from one version to the next, usually because of the Node community's love of bundling pre-compiled x86-only binaries into their git repos.  I do not under any circumstances alter the source code of Signal Desktop itself, nor of any of its dependencies.  If you're curious about the modified build files for a given version, and/or would like instructions to reproduce these builds yourself, send me a message.
  • The Ozone build provides native Wayland support, no Xwayland required.  Ozone is the name in the Chromium project (and thus in Electron, which Signal Desktop is built on) of a relatively new abstraction layer which modularizes GUI support.  This is highly experimental, requires on my end an Electron build with custom build configuration, and is not in any way supported by upstream Signal Desktop.  I'd very much like feedback on these builds, but do not be surprised if there are major bugs!
Signal Desktop Builds for Manjaro aarch64 - by ninefathom - 06-24-2020, 05:36 PM
  Manjaro Sway Theme Broken Eighty8 1 308 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,786 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 362 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,202 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,285 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 430 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 926 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,040 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,007 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 787 08-18-2023, 02:06 AM
Last Post: juliamenendez
