[SOLVED] PBP will no longer power on
Adapter arrived today and was indeed able to use it to recover. I used 2nd PBP to dd their entire drive to IMG file then dd'd that to my drive at which point it booted just fine.
Of note support did have me try bypassing the eMMC and using android image on SD to boot however that too had no response from pressing power button; it wasn't until I had restored the eMMC and pressed the reset button that it then started working again.
Thanks again brzegorz for the tip
[SOLVED] PBP will no longer power on - by s3rvant - 06-20-2020, 12:03 PM
RE: PBP will no longer power on - by TDC_PBP - 06-20-2020, 01:18 PM
RE: PBP will no longer power on - by Phillip Bell - 06-20-2020, 01:52 PM
RE: PBP will no longer power on - by s3rvant - 06-20-2020, 02:56 PM
RE: PBP will no longer power on - by s3rvant - 06-24-2020, 10:26 AM
RE: PBP will no longer power on - by brzegorz - 06-25-2020, 07:16 AM
RE: PBP will no longer power on - by s3rvant - 06-25-2020, 07:53 AM
RE: PBP will no longer power on - by s3rvant - 06-30-2020, 07:28 PM
  Lockable-until-power-cycle persistent storage Melab 0 767 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 879 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 661 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,326 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,405 09-09-2022, 08:13 PM
  Pinebook pro no longer boots xsquared93 7 7,696 02-13-2021, 09:39 AM
  Replacement Power Cord recommendation? nathanielwheeler 3 3,394 01-23-2021, 06:43 PM
  [SOLVED] Red light flashes next to barrel-port Carl 31 43,656 01-18-2021, 09:34 AM
Last Post: dsimic
  power light blinking during charge when pbpro is off Idaho 0 1,841 01-04-2021, 10:53 AM
Last Post: Idaho
  pbp no longer boots tulsums 12 10,630 12-03-2020, 11:29 AM
