[split] Change password from external media
Perhaps only a minor update to the original question I posted earlier. Reason for the delay in this posting, there was a problem on my desktop computer that had prevented me from entering or using ANY sudo commands. The OS on the desktop is Ubuntu 18.04.4 LTS. I followed some suggestions from a user forum for Ubuntu and, basically, reinstalled the OS from a DVD. Once at a menu for setup options, I was able to reset the owner's (my) password and the root password. I also had found another user listed on the computer with a deleted account. I had been unable to delete that user until after resetting my own password. Once that had been completed, I managed to burn a copy of the Manjaro ISO that was downloaded earlier onto a micro USB. With that in the PBP I am now able to at least get to the desktop and into some of the settings. I have not been able to connect to the Internet even though the PBP would use the same WiFi router as my desktop computer.
The questions that remain: At present, the only way I am able to even get to the desktop is with the USB card in the PBP reader at boot. I would prefer to be able to power the laptop on and use it without needing the USB card in the reader. The other question or problem is the WiFi Internet connection. What might I be doing wrong? Thank you for all the help and encouragement this forum has been.
James Good
RE: [split] Change password from external media - by James Good - 07-22-2020, 02:28 PM
  oem password iwm 8 2,426 02-19-2023, 07:35 PM
Last Post: iwm
  Issues with External Display After Recent Update reundo 0 1,382 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,222 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  My pbp is a sleek, black, flat brick, and won't boot from any kind of media rotwang 15 13,927 08-24-2021, 04:25 PM
Last Post: bkenn
  Graphical login hanging after password entry mhill8 2 3,377 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  External DVD/CD MIchael 22 22,203 03-07-2021, 03:49 PM
Last Post: ab1jx
  External Monitor Recommendations SteveSquatch 1 1,815 02-17-2021, 08:23 AM
Last Post: Arwen
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,764 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  [split] U-Boot with NVMe support, keyboard & display working as400 83 82,992 01-27-2021, 12:48 AM
Last Post: as400
  MAC address change user0258 2 3,510 09-16-2020, 01:12 PM
Last Post: user0258
