External Monitor Recommendations
Hey guys,
I'd like to setup a dock at my desk that connects my Pinebook Pro to an external monitor (plus keyboard, mouse). Any recommendations for how this setup should look? (ie. distro, USB-C hub, monitor)
This is the hub I currently have:
https://www.amazon.com/gp/product/B07XKR...UTF8&psc=1
I'm definitely not against getting another hub if somebody recommends something else.
I've had zero luck so far getting this external monitor to work with my Pinebook Pro thru Manjaro:
https://www.amazon.com/gp/product/B085ND...UTF8&psc=1
I'm on Armbian now, haven't tried that monitor yet (though I broke the mini-hdmi port, so I'll eventually get around to fixing it, though I'm not against buying a different monitor).
Thank you for any suggestions.
@SteveSquatch It looks like it should work. From what I can tell, (the specs aren't clear as some other docking stations), it appears that your docking station does use USB-C alternate DisplayPort mode, with active converter to HDMI connector. That is the correct thing for our Pinebook Pros. Any docking station that uses USB-C alternate HDMI mode will never work with our Pinebook Pros. USB-C tries to be everything, but ends up being confusing.
Has that monitor ever worked with HDMI on your docking station?
On any computer?
Arwen Evenstar
Princess of Rivendale
  Issues with External Display After Recent Update reundo 0 1,372 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,190 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  External DVD/CD MIchael 22 22,091 03-07-2021, 03:49 PM
Last Post: ab1jx
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,804 01-17-2021, 01:50 PM
Last Post: BananaPekan
  [split] Change password from external media James Good 11 12,830 07-23-2020, 02:42 PM
  Cloud backup recommendations Phillip Bell 4 4,976 07-14-2020, 11:06 AM
Last Post: rmtodd
  USB-C to 4k monitor: right 1/3 not working robt 4 5,407 07-12-2020, 02:46 PM
Last Post: robt
  Battery draining with external power while under load? RndmNmbr 17 18,793 06-24-2020, 08:33 PM
Last Post: Syonyk
  Audio jack and external mic? johns 5 7,047 06-10-2020, 12:42 PM
  Always in 'Charging' state, despite being disconnected from external power phuzy 13 13,470 03-26-2020, 04:12 AM
Last Post: agurenko
