emmc boots intermittently?
(06-08-2020, 01:36 PM)tophneal Wrote: You might want to try removing the back panel and ensuring the eMMC is properly seated on the board.
I did open the back, and the emmc is well seated. The boot from the emmc is still cranky and intermittent.
(06-08-2020, 03:13 PM)Arwen Wrote: @haziz , I had similar problems with Manjaro on eMMC. My PBP was from an earlier batch, so I manually loaded Manjaro. It seemed to work for a few boots, but them black screen. Booting the same version on SD card worked fine.
Turns out the U-Boot for Manjaro, both the Pine64 version and from Manjaro web site, is not as reliable as default Debian I had been using. Whence I restored those boot files, (but left "/boot" and "/" alone), Manjaro works great. (At least all that I have played with.)
Just the u-boot.itb file or everything in the boot partition?
Thanks.
Thanks.
Actually the Debian image does not even have a uboot file, it does have "rk3399-pinebookpro.dtb" and a couple of others.
emmc boots intermittently? - by haziz - 06-08-2020, 01:25 PM
RE: emmc boots intermittently? - by tophneal - 06-08-2020, 01:36 PM
RE: emmc boots intermittently? - by haziz - 06-08-2020, 03:36 PM
RE: emmc boots intermittently? - by bcnaz - 06-08-2020, 01:54 PM
RE: emmc boots intermittently? - by haziz - 06-08-2020, 02:32 PM
RE: emmc boots intermittently? - by Arwen - 06-08-2020, 03:13 PM
RE: emmc boots intermittently? - by Arwen - 06-08-2020, 06:47 PM
RE: emmc boots intermittently? - by mammbo3 - 06-08-2020, 07:22 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 61,016 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,577 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,314 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,779 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,345 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 2,114 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,480 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,861 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 3,235 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,475 09-28-2022, 06:22 PM
