Armbian for the Pinebook Pro [WIP]
WIP Armbian OS images for the Pinebook Pro are now available.
Download Page
very pleased with the pace of things with the pbp, i haven't seen anything like it before outside raspberry pi stuff. i'm spending a lot of time lurking here just to see things develop in front on my eyes.
Looks good for now. Konsole does not crash on dmesg, Stella runs fine on software rendering, Kubuntu PPA works fine. Tomorrow I can try KDE Neon and upgrade to 19.10. For now, it looks very stable and usable. OpenGL renderer is just llvmpipe, but the performance is nice.
edit: sound does not seem to work
edit2: neither I do not see the battery percentage
edit3: sleep is not supported (or disabled)
(01-19-2020, 04:05 PM)Wizzard Wrote: Looks good for now. Konsole does not crash on dmesg, Stella runs fine on software rendering, Kubuntu PPA works fine. Tomorrow I can try KDE Neon and upgrade to 19.10. For now, it looks very stable and usable. OpenGL renderer is just llvmpipe, but the performance is nice.
You checked the Bionic image, right? On Buster I had a problem with wifi, but the whole overall also looked good (also without sound, battery and sleep).
Yes, Bionic, I installed all of the KDE packages I use on regular Ubuntu install. Will play with that tonight to check the sound issue.
Ok, so this is what I found;
- there is no problem upgrading to 19.10 also with Kubuntu PPA enabled
- sound works after some playing. I installed all Phonon packages and played with Audio settings in KDE and it finally works.
- Stella finally runs at full speed also in OpenGL and OpenGL ES mode
- Konsole does not crash on dmesg command
- I can install Krita (there is arm64 package available)
- Sleep mode is supported (but waking up does not work, there are some error messages in console after and I have to reboot)
- battery status is not shown yet
This looks to be an ideal OS for me so far.
Also, I am trying to solve this issue:
sudo apt update
Hit:1 http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu eoan InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports eoan InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports eoan-security InRelease
Hit:5 http://ppa.launchpad.net/libretro/stable/ubuntu eoan InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports eoan-updates InRelease
Hit:7 http://ports.ubuntu.com/ubuntu-ports eoan-backports InRelease
Hit:8 http://ports.ubuntu.com/ubuntu-ports eoan-proposed InRelease
Hit:3 https://apt.armbian.com eoan InRelease
Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 26, in <module>
    col.create(db)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 93, in create
    self._fill_commands(con)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 127, in _fill_commands
    self._parse_single_commands_file(con, fp)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 165, in _parse_single_commands_file
    suite=tagf.section["suite"]
KeyError: 'suite'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 145, in apport_excepthook
    os.O_WRONLY | os.O_CREAT | os.O_EXCL, 0o640), 'wb') as f:
FileNotFoundError: [Errno 2] No such file or directory: '/var/crash/_usr_lib_cnf-update-db.0.crash'
Original exception was:
    col.create(db)
KeyError: 'suite'
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
.png   Screenshot_20200120_203754.png (Size: 58.59 KB / Downloads: 514)
.png   Screenshot_20200120_204036.png (Size: 76.28 KB / Downloads: 549)
Armbian, Running debian, not ubuntu. Anyone have any luck getting wifi to connect? it's on, and sees networks, but fails on connection, as if the password was wrong. (It's not, tried three different networks I control, and failed connecting to any of them)
I'd love to have 'pure' debian stable (sort of) running on my pinebook pro, instead of oldstable.
Yesterday I made another test with Armbian Ubuntu, installed KDE Neon on Bionic and it also runs well, including acceleration and sound. Sleep does work too, but does not wake up. Battery status does not work.
I found out that the following previous error is caused by changing bionic to eoan of focal in sources list. When I change that, this error appears after running apt update.
   col.create(db)
Seems that KDE Neon does not have kernel module working.
.png   Screenshot_20200121_184801.png (Size: 57.73 KB / Downloads: 500)
Nobody using Armbian Ubuntu?
Today I upgraded to 20.04 and it runs fine, accelereation and sound works, battery not. Stella runs fast! Smile
  Debian on Pinebook Pro u974615 7 1,318 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,833 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,341 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,981 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,345 11-23-2023, 07:37 AM
  USB 3 port not working with Armbian zaius 3 923 11-13-2023, 01:54 PM
Last Post: zaius
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,486 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,555 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,667 08-07-2023, 01:12 PM
Last Post: myself600
