Manjaro stuck on boot
Hey
I'd like to switch from Debian to Manjaro. I tried to flash the KDE and the XFCE eMMC installer as well as the sd card versions to sd cards. The eMMC version always gets stuck in the startup screen. Same things happens after installing the sd card versions onto the sd cards. Is there anyone having the same problem and knowing a solution?
I experience this as well, I tried switching to TTY2 from the boot logo (ctrl + alt + F2) and it just put me into the installer. If not, try switching between different TTYs (aforementioned combo with F1, F2, F3, etc up to 8 or so).
(01-04-2020, 10:40 AM)whadduppp Wrote: Hey
Can't speak to the KDE installer, but for the XFCE installer this is a known bug. I believe the current working solution is to press ESC after 30s.
  Manjaro Sway Theme Broken Eighty8 1 334 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,808 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 383 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,245 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,344 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 460 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,390 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 967 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,063 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,033 08-21-2023, 09:08 PM
