Trackpad firmware update
#91
(12-20-2019, 08:11 AM)Luke Wrote:
(12-20-2019, 07:42 AM)Kochise Wrote: Tell us what happened and how it was solved (in the case someone else experience the same issue)
Or better yet, please add as a troubleshooting step to wiki... thanks Smile
I will, as soon as i can get it (including m'self) together.
#92
@tllim , @xalius , @ayufan and @anarsoul ,
Just got around to updating the trackpad firmware. The process was simple and did not produce errors. I am writing this with the update applied with the trackpad on, and am not using an external mouse.
I am pleased to report that the palm detection is fixed, it no longer blocks characters from being typed. I still have to keep my meaty thumbs from interacting with the pad though, otherwise I cause inadvertent cursor movement and text selection. It is quite pleasant typing now, even with the trackpad on.
Thanks for this!
#93
How could I check version of the firmware?
I've got PBP Dec 2019 ISO and the touchpad works to me a little weird.
#94
Those of you who got their PBPs in late 2019 and early 2020, please do the following to determine which firmware you have:
1) open a terminal window
2) place on finger on trackpad
3) type any letter
Report if the letter you typed showed up. If it did, good, its the newest firmware.
#95
(01-01-2020, 05:58 AM)Luke Wrote: Those of you who got their PBPs in late 2019 and early 2020, please do the following to determine which  firmware you have:
3) type any letter
Well, apparently I've to update, there was no letter.
#96
Looks like the factory messed up then ...
I need a few more confirmations - so others with new PBPs please test this too.
#97
(01-01-2020, 07:18 AM)Luke Wrote: Looks like the factory messed up then ...
I need a few more confirmations - so others new PBPs please test this too.
Hi Luke,
Received on the 30th Dec UK.
I did your test.... NO letters show while touching the trackpad.
Firmware needs updating.
P.M.
#98
@Luke received mine today (ISO version, ordered beginning of November). I can also can confirm that no letter shows up when one finger is on the trackpad while typing.
#99
Thanks, will make the announcements soon and try to get the word out ...
Thanks for the notification on twitter. I followed the update instructions and all is working well so far.
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,414 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,105 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,125 02-22-2023, 03:23 PM
Last Post: robocone
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 2,040 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,426 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,458 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,167 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 6,152 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,420 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,653 10-19-2021, 01:57 AM
Last Post: j4n3z
