Wont charge when powered off, and update question
Just started using it this week, updated Manjaro, selected hibernate in gui and it did nothing so I did shutdown. Then later when I press power it would power on but to a black screen for a few seconds and then shutoff... Wtf did it battery drain due to the hibernation error??? Then I realized it only will charge when USB C is in when its on and got it to boot again, this seemed dangerous, potential brick how to fix?
Also I am trying to fix this annoying laggy mouspad from https://github.com/dragan-simic/pinebook...rd-updater here, got a simple question, on this git page it says
thus, if you use the packaged version, replace ./updater in the instructions below with pbp-fwupdate. Please note that the Manjaro package provides no custom keymaps described later in this documentation.
Huh there is an update utility for the PBP? Seems hard to believe, >sudo pacman -Syu pbp-fwupdate = error: target not found: pbp-fwupdate
Well shit... My question is it better to do this mousepad/ keyboard update with this "Firmware updater utility" (I cant pacman the "packaged version??") or not (just use ./updater as said above).
Is there a proper tutorial anywhere on how to properly update the PBP stock manjaro? Undecided
It looks like you were first in the right place to find the proper firmware updater. Mangaro nor any other operating system that I'm aware of will (nor should) do this.
Keep in mind that what you are doing to fix the touchpad is an actual firmware update, as in real firmware, not a software update a la Linux "firmware".
:wq
(12-06-2021, 07:26 PM)KC9UDX Wrote: It looks like you were first in the right place to find the proper firmware updater.  Mangaro nor any other operating system that I'm aware of will (nor should) do this.
Uh.. So do you mean I should use "pbp-fwupdate" in place of "./updater" from the instructions in the github? What is the benefit of using it over the standard ./updater ? Tough crowd here, not much help, vague. Appreciate you atleast responding.
If you are using the git,, use ./updater,,,, for the 2nd stage, be aware that you have to cd to the git directory
(since updater is in the git directory and not in any path)
The manjaro package had the same software, but setup a little differently,
but you did NOT get it installed so pbp-fwupdate will give you a "file not found" message
This is if I understand your post correctly...........
(12-06-2021, 05:44 PM)pineymousepad Wrote: Huh there is an update utility for the PBP? Seems hard to believe, >sudo pacman -Syu pbp-fwupdate = error: target not found: pbp-fwupdate
If you want to use pbp-fwupdate, you have to install the proper package which is pinebook-pro-keyboard-updater. The name of the package is not always the name of the command. Instructions are right before the ones you quoted:
Quote:The name of the package is pinebook-pro-keyboard-updater, and the firmware update command is named pbp-fwupdate
Using the packaged version is easier because you don't have to compile the software yourself. But:
Quote:Please note that the Manjaro package provides no custom keymaps described later in this documentation.
Thank you so much for this post, I just did >sudo pacman -Syu pinebook-pro-keyboard-updater ....
Total Download Size:    818.24 MiB
Total Installed Size:  2828.11 MiB
Net Upgrade Size:       -36.76 MiB
HOLY SH!*@#* ALMOST 3GB??? I must be missing something, please clarify.. I am assuming "custom keymaps" is unnecessary.
Thanks again, will rate anyone helps me here.
(12-09-2021, 07:10 PM)pineymousepad Wrote: I just did >sudo pacman -Syu pinebook-pro-keyboard-updater ....
That's because you ran pacman with the -u flag which is updating all your installed packages that have newer versions available. You probably haven't updated in a while. If you only want to install the package, omit the -u flag. But it's advisable to keep your system updated.
OK I updated and put my pinebook in sleep mode, now a day later it won't turn on, great... I press the power and see the power led on (after charging a bit, seems drained) but nothing shows on the screen, WTF?
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  GPIO breakout question pinus_pinea 1 3,197 10-05-2024, 08:58 PM
Last Post: brken
  Locked out after update Shylocked 5 5,642 09-13-2024, 07:40 AM
  uboot wont boot to SD card after upgrade jbradley419 7 9,606 01-19-2024, 02:29 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,605 12-15-2023, 02:11 PM
  Newbie Question!! oniichann 3 4,750 10-26-2023, 07:09 AM
  After update, multiple problems, pinebook pro. jd50i 1 4,213 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,062 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,645 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,356 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 5,713 07-22-2022, 01:19 PM
