Keyboard/Touchpad update SH61F83 IC
My PBP has been sitting idle for a while as I've been busy with other things, blown the dust off and looking to get back into learning ARM, I want to bring the keyboard & touchpad up to date as they are sill in the original shipped state but my machine has the SH61F83 with the limited reflash capability. My machine dates from jan 2020 (date of receipt, ordered Nov 2019) Can somebody point me to the correct firmware updates and procedure since I don't have the reflashes to play with.
Ray Sutton
(03-28-2022, 09:08 PM)zaphod80013 Wrote: Hello,
Ray Sutton
https://wiki.pine64.org/wiki/Pinebook_Pro#Keyboard
Ray Sutton
Thanks, on first read i wasn't clear if that was just the trackpad update. After rereading it, it makes more sense now, I've successfully applied the update(s) and keymap corrections. From the other reading i'd done in the meantime there was one item (on Reddit I think) that implied the 8 flash limit on the SH61F83 isn't real. Is that correct or does the limit apply. Just curious for future reference.
I am also curious on this; I have an August 2022 batch PBP, and I also have the SH61F83 IC.
Has there been any more information since on the 8 flash limit? Looking up the chip information I still see 8 write cycles on it.
https://datasheetspdf.com/pdf/1252851/SI.../SH61F83/1
I would also like an update on this regarding the 8 write cycles limit. My PBP that I bought just 2 weeks ago also has the SH61F83...
I did however manage to update my firmware twice as seen in my recent post. 1st update failed and 2nd one succeeded.
Would like to try to flash custom keymap firmware as well but too scared I will reach write cycle limit.
  Keyboard issue j0rs 3 5,668 01-20-2025, 07:03 AM
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,910 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 4,152 11-25-2024, 03:42 PM
  Locked out after update Shylocked 5 5,768 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,737 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,288 09-16-2023, 09:41 AM
Last Post: jd50i
  Dead Pinebook Pro Keyboard Keys calinb 2 4,502 09-02-2023, 12:31 PM
Last Post: calinb
  power on Pinebook Pro mainboard without keyboard? papable 0 3,049 07-20-2023, 11:06 PM
Last Post: papable
  Finally... The touchpad works great! dsimic 111 236,910 03-13-2023, 09:41 PM
Last Post: kellrobinson
  Metis package can't update Mangustis 1 4,144 02-22-2023, 03:23 PM
Last Post: robocone
