REMOVE ROCK64 BOOT LOGO
is there a way to remove the ROCK64 boot logo ?
I could change the android logo with a bootanimation.zip, but it still remain ROCK64 logo.
Any help will be appreciated.
Aurel
(03-15-2019, 12:44 PM)aurel Wrote: Hello,
Aurel
You have to replace the .bmp files in the root of the kernel directory and rebuild the kernel and install it
however you do it you will first need root. and you also need to grant write priviledge to the system directory. then you can just rename the current bootanimation. then just name the new file to bootanimation.zip. at least that's the way i did it from android 13 to 15. might have changed. also, i've never done it on these pine64 builds so maybe shripal17 is right about having to do what he says.
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,365 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android Images (ROCK64) pineadmin 73 169,276 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,054 03-12-2021, 01:38 PM
Last Post: Wizzard
  Android on Rock64 SD Problem ElBoluTony 3 6,086 10-07-2020, 12:10 PM
Last Post: ElBoluTony
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,773 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,892 09-09-2020, 08:44 AM
Last Post: BowerR64
  Boot Android from USB? Max_H 3 6,609 09-09-2020, 08:26 AM
Last Post: BowerR64
Question Regular Android build for Rock64? fender90 18 26,564 09-09-2020, 08:04 AM
Last Post: BowerR64
  Minimum requirements for ROCK64 Android install? eugenev13 0 2,747 06-04-2020, 02:23 AM
Last Post: eugenev13
  Android 10 for Rock64? Blinky 0 3,714 04-21-2020, 12:55 AM
Last Post: Blinky
