Camera interface with rockpro64
I am just about to buy Rockpro64 board. I am going to use Linux image on that. With that i want to have some camera applications such as Orbslam.
Please confirm which best camera should i use with Rockpro64. As i found few cameras which are either given to be supported with the Pin64+ level boards or with Android stock.
Thanks.
(09-24-2018, 11:19 PM)rahulsharma Wrote: Hi,
Thanks.
Did you see this listing on the store?
https://www.pine64.org/?product=rockpro6...dard-model
Yes i saw that. But it is givrn - Currently only stock Android build available, the community Linux build not yet support camera driver.
And i have said that i am going to use linux on it.
Thanks for the reply.
Yes i saw that link but there is given that the camera module is only supported for stock android version not for linux.
And i have said that i will be using Linux on my Rockpro64 board.
So please tell me the best camera that is supported on Rockpro64 board having linux OS.
Thanks.
It will be great if i get the confirmation asap:-).
Will Pine64 5 MP camera work with Rockpro64 camera? If yes then does it have Linux driver support?
Thanks.
  Installing Wifi drive for the RockPro64 John45595 0 346 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 817 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 710 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,363 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 929 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,375 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,889 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,764 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,043 01-27-2023, 07:43 PM
Last Post: Spater
  PCIE interface power on too late Slark Xiao 0 1,044 11-29-2022, 11:56 PM
Last Post: Slark Xiao
