[EXPERIMENTAL] Linux on the LCD screen
Coming soon on Linux...
[Image: 20160920_143949.jpg]
Currently, it only lasted for 5 to 6 seconds before my Pine powers down (i guess it is due to not enough power) , which means i can't test it out to see if it's truly working or not.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
(09-20-2016, 01:00 AM)Terra854 Wrote: Coming soon on Linux...
Are you kidding?! There's nothing that could 'come' since it's there from the beginning. It's just defining that you want to use an LCD instead of HDMI (or configuring how you want to combine two displays to be used at the same time) and it's done the usual way we're doing this on every other Allwinner SoC with BSP kernel since years: http://forum.pine64.org/showthread.php?t...9#pid20149
There's nothing 'experimental', the BSP kernel was able to use the LCD from the beginning, it's just different settings. And it's still done the same way as we know it from older Allwinner SoCs and BSP.
The only problem this community here had or still has is it that some people were so blinded by 'the Mali' hype that they didn't realize that if you want to use an LCD you have to switch settings to use the LCD. No 3D acceleration needed for using a display! Read through the above thread to get the sad details.
Yes, I am aware that support is already included since the beginning, it is just a matter of getting it to work correctly with the correct settings in the dts.
So far, it does not work properly yet as it blank screens after a few seconds (that's why i put "EXPERIMENTAL" to say that it's not ready for normal users because we either haven't discovered the correct settings for it or it's due to other factors, not because I am experimenting with support for the LCD screen).
(09-20-2016, 02:25 AM)Terra854 Wrote: Yes, I am aware that support is already included since the beginning, it is just a matter of getting it to work correctly with the correct settings in the dts.
Thanks for the clarification. In case you power your whole setup through Micro USB then... well, then...
That's why I call the Pine64 (and every other device out there relying on Micro USB for DC-IN) a supporter's nightmare. You never know what happened if something's reported as broken. It might just be the usual undervoltage situation responsible for the many problems people are experiencing with their boards.
The LCD backlight might add significantly to consumption -- who knows what happens then if powering is insufficient...
Bleh.. I've tried
wget -O /boot/dtb/allwinner/sun50i-a64-lcd-pine64-plus.dtb https://raw.githubusercontent.com/ayufan...4-plus.dtb
sed -i '1isetenv fdtfile sun50i-a64-lcd-pine64-plus.dtb' /boot/boot.cmd
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
reboot
Step by step please since you make it sound so easy and it's already there. =P All i'm getting at is tons of segmentation errors on xenial-pine64-bspkernel if trying to install Mate Desktop or apt-get upgrade -y .. And, an armbian that can't even detect Ethernet to ssh to. Atleast dood is trying to do something there no thanks to everyone here..
Well, less is more. It's easier than I thought.
Again, this is only on debian base. I recommend you update the kernel first to 3.10.104-1-pine64 with the update scripts:
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_uboot.sh)
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh)
Reboot.
Login as root and
wget -O /boot/pine64/sun50i-a64-lcd-pine64-plus.dtb https://raw.githubusercontent.com/ayufan-pine64/device-pine64-common/19545248d729d0ddf056d3bed85eeee4a238ffd5/bootloader/pine64/sun50i-a64-lcd-pine64-plus.dtb
echo "fdt_filename_prefix=pine64/sun50i-a64-lcd-" >> /boot/uEnv.txt
systemctl disable sunxi-disp-tool
Reboot
I have detailed installing the touch driver on my github:
https://github.com/atomicmooseca/pine64-gt9xxf_ts
(12-16-2016, 11:47 PM)atomicmoose Wrote: I have detailed installing the touch driver on my github:
Cool! Will test it out now and if it works, I will include the driver in my images.
I came here from the locked "LCD Support on Linux" thread and have a question: The linked Images by pfeerick are all (x)ubuntu, and the tutorial by atomicmoose is for Debian... How can i get the Touchscreen working with me? and the script is not working for me either... Sad I installed the Image with Armbian 5.24 and Linux Kernel 3.10.104. Can you help me, I'm not that into Linux, my only experience are some raspberry pi Experiments and a bit Desktop x64 fun Big Grin
This was helpful. I was able to compile and install the module on Gentoo Linux. The touch screen works but only the right half of the screen. Can you share what .dtb or .dts file you're using?
Information LCD Support on Linux pfeerick 8 19,273 02-08-2021, 03:30 PM
Last Post: HBeserra
  What other devices can the LCD screen work on? kodachrome 1 3,127 12-07-2019, 06:50 PM
Last Post: kodachrome
  Linux Support UnixOutlaw 69 91,127 03-18-2017, 07:25 PM
Last Post: apple4ever
  LCD screen brightness/contrast Learnincurve 10 13,982 02-17-2017, 12:45 PM
Last Post: psychedup
  Touch screen support shariq_2001 14 20,010 12-07-2016, 07:47 AM
Last Post: Luke
  LCD Touch Screen Problem. Gavin 8 9,733 11-27-2016, 10:26 PM
Last Post: michaelquezon
Photo Playbox LCD on Linux MackPI 10 16,165 10-19-2016, 07:49 AM
Last Post: Zoidiano0
  Screen flashes blue and then goes dark. tanarri 5 7,755 06-22-2016, 10:53 AM
Last Post: tanarri
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 5,122 06-13-2016, 08:24 AM
Last Post: PapaStahl
  LCD screen not powering on Dnode 16 21,163 06-08-2016, 12:59 PM
Last Post: anexpert
