LCD Pannel working... Touch screen NOT working?? Why
As the title suggests My Pine 7" LCD is working (showing graphics) but not responsive to touch at all. Im booting the LCD android 5.1 from the wiki.
The only thing I can think of, is look how sheet the ribbon cable plug was attached to the board from factory. I couldnt say If its the problem but Its suspicious.
 [Image: 13313604_1183537048365249_91336053_o.jpg]
(05-30-2016, 02:00 AM)Chopshop13 Wrote: As the title suggests My Pine 7" LCD is working (showing graphics) but not responsive to touch at all. Im booting the LCD android 5.1 from the wiki.
The DSI connector just for LCD panel and your connection looks correct. For touch screen to work, you need to connect the thin flex cable to the TP port.
(05-30-2016, 02:50 PM)tllim Wrote: The DSI connector just for LCD panel and your connection looks correct. For touch screen to work, you need to connect the thin flex cable to the TP port.
Ahhh I seeee. Thanks.
Thank you so much ChopShop13 for asking the question and to tllim for answering! I had the same issue! Now I'm up and running with both HDMI and the LCD panel (on separate cards) (and off to searching for the next issue)!
  7 inch LCD touch panel is upside down? joshpl 2 1,711 12-07-2023, 06:18 AM
Last Post: stormwyrm
  What other devices can the LCD screen work on? kodachrome 1 3,115 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 35,414 07-21-2017, 07:41 AM
Last Post: apple4ever
  I2C Touch Panel mbt28 0 2,133 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD screen brightness/contrast Learnincurve 10 13,949 02-17-2017, 12:45 PM
Last Post: psychedup
  LCD touch panel emits low power Naccies 4 6,300 01-09-2017, 07:45 PM
  Touch screen support shariq_2001 14 19,981 12-07-2016, 07:47 AM
Last Post: Luke
  LCD Touch Screen Problem. Gavin 8 9,717 11-27-2016, 10:26 PM
Last Post: michaelquezon
  LCD Panel not working at all treize 7 10,001 09-19-2016, 10:24 PM
Last Post: billjon
Photo Running Out Of Options LCD Panel Just Not Working AUDIOTEK 4 5,047 07-27-2016, 06:34 PM
Last Post: AUDIOTEK
