LCD screen brightness/contrast
Just wondering if there is any configuration tweak to increase the brightness/contrast of the 7"LCD panel?
BR.
-Marius--
Facing same problem here. Brightness and contrast too low, but my LCD came with vertical stripes, usually should be dead pixels but unfortunately it is broken (dead stripes).
I will post a video so you can have an idea if you have the same problem. I have read somewhere ( i can't remember where ) it is a back-light issue so it seems just a matter of turning the back-light on.
Learnincurve, please see if you have similar problem. The odd thing is that the stripes are really bright and the purple background color on Unity greeter cannot be seen.
What you see here is is TSLIB and X11 in action (please turn off sound): https://drive.google.com/open?id=0B7A7OP...URhemlOT0U
(02-10-2017, 08:21 AM)Learnincurve Wrote: Hi,
BR.
-Marius--
Don't know about the contrast but this turns the brightness up to 100% for me:
# echo 362 > /sys/class/gpio/export
# echo out > /sys/class/gpio362/direction
BR.
-Marius--
Thanks, this helped to find the thread, it is from pfeerick: http://forum.pine64.org/showthread.php?tid=2896
I think  you must write some value to the pin to make it work as in the thread. seems not.
Thanks!
I don't have any vertical stripes on my screen, but the 362 out tweak did the trick!
Screen is nice and bright now!
BR.
--Marius--
Turning up to full brightness and turning off work well, by following:
# echo out > /sys/class/gpio362/direction (turns up to full)
# echo in > /sys/class/gpio362/direction (turns off backlight)
I can also turn on and off by echoing:
# echo 0 > /sys/class/gpio362/value (turns on)
# echo 1 > /sys/class/gpio362/value (turns off)
but, when the system boots without manipulating these, the backlight is on, but dim. I can't find a way of reverting to that after doing the first:
pfeerick 's thread seems inconclusive on other values.
The pin that controls the backlight is actually a hardware PWM output. If you program the PWM or use a linux backlight driver that supports GPIO-PWM you should be able to control brightness like on the Android images.
Thanks, will look into it. Out-of-the-box the pin is obviously being fed by PWM control. Can you point to where this is configured and turned on at boot?
BR.
For the BSP (3.10.x) kernel the PWM output (PL10 according to the schematics) is afaik tied to the LCD driver and there should be some controls in the /sys/ filesystem.
If you look at the device tree:
Pin Config:
https://github.com/longsleep/build-pine6...4.dts#L776
LCD Entry seems to have values too:
https://github.com/longsleep/build-pine6....dts#L1965
PWM Driver entry, from the pinctrl phandle:
https://github.com/longsleep/build-pine6....dts#L2071
from the compatible line it should be tied to a driver called "sunxi-pwm16"
  What other devices can the LCD screen work on? kodachrome 1 3,107 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 35,388 07-21-2017, 07:41 AM
Last Post: apple4ever
  Adjust brightness of LCD on Armbian Desktop with 1 click JulianM 0 3,289 04-02-2017, 09:23 AM
Last Post: JulianM
  Touch screen support shariq_2001 14 19,958 12-07-2016, 07:47 AM
Last Post: Luke
  LCD Touch Screen Problem. Gavin 8 9,707 11-27-2016, 10:26 PM
Last Post: michaelquezon
  Screen flashes blue and then goes dark. tanarri 5 7,739 06-22-2016, 10:53 AM
Last Post: tanarri
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 5,098 06-13-2016, 08:24 AM
Last Post: PapaStahl
  LCD screen not powering on Dnode 16 21,112 06-08-2016, 12:59 PM
Last Post: anexpert
  Petition thread for screen larger than 7inch MostHated 4 5,390 03-02-2016, 03:40 PM
Last Post: MostHated
