link for supported pinephone os manjharo et all
Hi-
the images at the manjaro site only have a checksum and the site looks funny like no CSS styling is applied.  It is just a bunch of hyperlinks.
Mobian didnt have a way to verify either.
I am desperate for an image. Can someone point me somewhere there is a cool image i can use with the pinephone that is supported?
I like manjaro gnome but v16 aiin't workin.
thanks,
jim
manjaro's github page has .img files for each release, and .sha256 for each .img https://github.com/manjaro-pinephone/phosh/releases
okay that is awesome.
THANKS!
I'm on Beta 36 since march, and now that I'm trying to reinstall Telegram on it, I keep getting oodles of 'not found' etc when it tries to synchronize package databases.
I gave up on Beta 29 because it wouldn't update because of one error (someone's sha signature was not found in the database). While 36 in general works better, this is... well, is there a workaround? I'd need to update just megapixels and to install Telegram.
  systemic issue pinephone penguins_rule 3 494 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 1,891 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,636 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,721 02-04-2023, 08:35 PM
Last Post: Westslope
  How to install iptables extensions? I get "Extension owner revision 0 not supported" anon4 0 2,197 08-27-2022, 12:19 PM
Last Post: anon4
  Pinephone craches after each call neithan76 2 1,652 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,929 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,136 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,745 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,932 04-07-2022, 06:02 AM
Last Post: danimations
