apt trying to install a package version not in the repo
So a combination of trying the commands
https://wiki.debian.org/Mobian/Tweaks#Au...pp_scaling (cause I wanted postmarketostweaks)
"apt update"
"apt upgrade"
has resulted in apt trying to install from "http://deb.debian.org/debian/pool/main/d/dbus/libdbus-1-dev_1.14.6-1_arm64.deb" However that 404s and looking up one directory in the url, I'm wondering where it got that version number, as versions 1.14.10-* are all older than my mobian install (I installed it this month!).
I have checked my sources files match the ones listed at https://blog.mobian.org/posts/2023/06/10/bookworm/
Given I now can't get apt install or remove cause of this I'd like to know how to fix this in either direction? Either remove what wants to install libdbus or get apt to fetch a version actually in the repo.
(yes I've already tried google I might not know the right search terms, so I'll happy take advice there too!).
(11-11-2023, 05:15 PM)chainingsolid Wrote: So a combination of trying the commands
"apt update"
"apt upgrade"
Did you look in this directory for a near version?
https://deb.debian.org/debian/pool/main/d/dbus/
  Waydroid install instructions end up attempting to use wrong URLS to aquire .debs chainingsolid 1 117 04-26-2024, 04:56 PM
Last Post: zetabeta
  Phoch Trixie weekly install seems nice reTestability 0 220 03-10-2024, 08:47 AM
Last Post: reTestability
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,106 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Debian bookworm security repo user641 2 1,626 02-17-2023, 01:12 AM
Last Post: user641
  Recent install, no wifi user641 3 1,537 01-12-2023, 03:06 PM
Last Post: user641
  snap install exceeded maximum runtime jojuma 0 806 07-17-2022, 07:52 AM
Last Post: jojuma
  tor onion address for repo.mobian-project.org? vusra 3 2,687 02-25-2022, 12:53 AM
Last Post: vusra
  Getting Newer Version of Nheko publiclewdness 2 2,147 10-27-2021, 06:16 AM
Last Post: publiclewdness
  gnome podcasts on debian repo, dino-mobile user641 3 3,307 09-11-2021, 12:04 AM
Last Post: user641
  Best/easiest way to install minimal Debian on PinePhone? mcgee 6 5,551 07-18-2021, 09:35 AM
Last Post: swiley
