snap install exceeded maximum runtime
Hi everyone,
seeking for help if this "project" is possible at all.
I want to install classic "Prince of Persia" from the snapstore. But no matter if I try online or offline after downloading the snap I get the same output:
sudo snap install sdlpop
[sudo] password for mobian:
error: cannot perform the following tasks:
- Run configure hook of "sdlpop" snap if present (run hook "configure":
/usr/share/fonts: caching, new cache contents: 0 fonts, 5 dirs
/usr/share/fonts/cMap: caching, new cache contents: 0 fonts, 0 dirs
/usr/share/fonts/cmap: caching, new cache contents: 0 fonts, 0 dirs
/usr/share/fonts/opentype: caching, new cache contents: 0 fonts, 3 dirs
/usr/share/fonts/opentype/cantarell: caching, new cache contents: 5 fonts, 0 dirs
/usr/share/fonts/opentype/noto:
<exceeded maximum runtime of 5m0s>
Is there something wrong with the fonts or can I take influence on the maximum runtime?
I am asking this here since on any other system installation was no problem and I can't find a solution in the WWW.
Thanks for advices
EDIT: There are versions for amd64, arm64, armhf, i386 and ppc64el. So this should work, shouldn't it?
EDIT: Since '/usr/share/fonts/opentype/noto' is a rather big folder, I thought the caching of it takes a lot of time and thus moved it to another location.
After that, the installation process went through without further problems. I copied the 'noto' folder back afterwards.
The game runs smoothly now and though I don't know if this is a proper solution due to future updates, I'll mark this as 'solved' for know.
Thanks!
  Waydroid install instructions end up attempting to use wrong URLS to aquire .debs chainingsolid 1 54 04-26-2024, 04:56 PM
Last Post: zetabeta
  Phoch Trixie weekly install seems nice reTestability 0 198 03-10-2024, 08:47 AM
Last Post: reTestability
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,021 11-22-2023, 11:46 AM
Last Post: aLoop100o
  apt trying to install a package version not in the repo chainingsolid 1 503 11-12-2023, 03:54 AM
Last Post: evilbunny
  Recent install, no wifi user641 3 1,486 01-12-2023, 03:06 PM
Last Post: user641
  I built a reminder app but can't seem to build a deb/snap/flatpak for it, help? ragreenburg 9 6,810 09-10-2021, 02:51 PM
Last Post: ragreenburg
  Best/easiest way to install minimal Debian on PinePhone? mcgee 6 5,464 07-18-2021, 09:35 AM
Last Post: swiley
  Cannot install spotify, librespot or mopidy Gon 3 3,654 06-18-2021, 06:53 AM
Last Post: Gon
  firefox 79 will not install motox6 1 2,189 05-08-2021, 02:09 AM
Last Post: MtnSk8
  How do I install pinephone-devtools? lsitongia 1 2,267 04-06-2021, 04:31 PM
Last Post: dukla2000
