Help installing Manjaro on eMMC of Pinebook Pro
Hello
Bought new Pinebook Pro, while updating I logged out and crashed login window theme software, I type the password and then it logs me in then logs me out back to login window, so to reinstall Manjaro I burned Manjaro on SD card and booted from that successfully. Manjaro installed itself on another partiton on SD card rather than eMMC, I then followed some tutorial and used a command to install Manjaroo in eMMC while running from SD card, Now I boot into uboot, some text shows up and now it wont boot from from neither SD card like it used to be able to, and not from USB drive. I used Balena etcher on ubuntu to burn the images on SD card and USB drive but both are not booting.
What shall I do to install Manajaroo in eMMC? I used to be able to boot from SD card using  Manjaro-ARM-kde-plasma-pbpro-22.12.img but not anymore. Now it just loads uboot and then goes to black screen forever.
Thanks in advance.
Rather get some other OS ...
Big Grin
I figured it out. I used the Manjaro image from the wiki and that worked fine and it booted from sd card. Then I used the Arm Flasher to flash eMMC and its working now Big Grin
(12-31-2022, 12:18 PM)pine4546464 Wrote: I figured it out. I used the Manjaro image from the wiki and that worked fine and it booted from sd card. Then I used the Arm Flasher to flash eMMC and its working now Big Grin
Any chance you remember how you did this, I'm in a similar situation. I can boot to Manjaro from sd card but can't figure out how to flash the eMMC
I would like to know which guides he followed also. I just recently managed to brick my install after a major update on Manjaro. Thankfully, I had the Emmc reader this time from the pine64 store, and I was able to backup my files from the emmc, and re-flash it.
  Debian on Pinebook Pro u974615 7 1,177 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 303 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,677 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,782 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 355 01-19-2024, 11:32 PM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,271 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,535 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 426 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,294 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 920 11-14-2023, 10:57 AM
Last Post: trifleneurotic
