Webcam not working in Manjaro with Cheese, but works in Armbian
The Pinebook pro webcam doesn't work either in Cheese or Kamoso with the preinstalled Manjaro, and it's definitely not a privacy switch issue as replies all over this forum suggest.
It actually works with any of these :
mpv /dev/video4
vlc v4l2:///dev/video4
guvcview-qt -d /dev/video4
It also works with webcamoid - that needs to be built from AUR although.
And it also works in a Jitsi echo test in Vivaldi : https://janus.conf.meetecho.com/echotest.html
However, the Webcam works out-of-the-box with Cheese using either Armbian or Twister OS (Both based on Ubuntu LTS), so I wonder what library or helper might be missing in Manjaro to get it working.
I tried to search for a while, but to no avail so far.
Any clue would be much appreciated.
I noticed the same - I suspect it might have something to do with Cheese trying to access /dev/video0 or something?
  Manjaro Sway Theme Broken Eighty8 1 303 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,782 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 355 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,184 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,270 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 426 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 920 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  USB 3 port not working with Armbian zaius 3 893 11-13-2023, 01:54 PM
Last Post: zaius
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,034 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,999 08-21-2023, 09:08 PM
