Mobian : Firefox, toolbar has moved to the bottom.
On my PinePhone Pro running Mobian the Firefox UI has automagically changed itself. The toolbars, Menu, URL field and buttons are all now at the bottom. I can't find the setting in Firefox to change it back. It is driving me nuts.
This is only on the PinePhone Pro Firefox on my PinePhone Firefox seems unchanged. Apart from applying available updates I have made no other changes to the OS and Firefox on this device. The PPP has been undated and rebooted this morning. Still no change.
Has there been a change in the files in userChrome, CSS etc that moves the UI elements around? If I know what has been changed then I have a chance of changing it back. Otherwise I can go and get the files created by Aris on Github to customise the Firefox UI and at least get the toolbar back at the top.
(03-06-2022, 01:27 AM)grump_fiddle_reinstall Wrote: On my PinePhone Pro running Mobian the Firefox UI has automagically changed itself. The toolbars, Menu, URL field and buttons are all now at the bottom. I can't find the setting in Firefox to change it back. It is driving me nuts.
Yes, the firefox-mobile-config package configures the toolbar via a configuration file. Inspecting the package should tell you pretty quickly, the changes are also explained here: https://wiki.mobian-project.org/doku.php?id=firefox-esr
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,123 04-28-2024, 01:52 AM
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 475 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 910 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 509 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 729 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 612 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,444 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,289 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 817 07-01-2023, 08:18 AM
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,105 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
