[Mobian] : Battery consumption and OS compatibility
I have bought a pinephone and the battery consumption is too high.
As i good understand, pinephone have a SoC AllWine A64 and that's why it drain a lot of battery and warm.
The advantage of this SoC is good supported linux mainlines.
With the pinephone pro, the Rockchip RK3399S SoC is an ARM. In theorical, it drain less battery.
It's right ?
What is the level compatiblity of pinephone pro with Mobian OS ?
-linux mainlines
-basic features
-app
Thank a lot for your feedback
The Allwinner A64 is also an ARM SoC. The PinePhone Pro's SoC actually drains more battery. But it is also significantly faster.
This doesn't directly address your question, but it might help you out.
I'm an electronics engineer who knows how to bench test batteries.  The one supplied with my phone tests at slightly over 2000mAh, so I ordered a genuine Samsung EB-BJ700BBU from Amazon, the one that the PinePhone wiki describes as "a tight fit".  It is a little bit tighter than the originally supplied battery, but nothing to get excited about, and it bench tests at slightly over 3000mAh ... I'm quite happy with it.
***   Don't be a minion in the (i)droid army   ***
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,870 Yesterday, 05:40 AM
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 467 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 889 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 500 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 710 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 602 10-14-2023, 11:57 AM
Last Post: mburns
  Battery life thread: discussion, support and tips apink 6 2,023 09-22-2023, 02:37 PM
Last Post: tookmeayear
  Mobian libnotify custom notifications MadameMalady 5 1,404 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,183 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 804 07-01-2023, 08:18 AM
