Chatty, SMS does not work - could hardware be at fault?
#31
(10-25-2021, 08:34 AM)AntonReiser Wrote: What do I have to do to reinstall the original firmware?
You can find the instructions to revert to the stock firmware here in biktorgj's repo.
Edit: You can also try switching out just the ADSP firmware as mentioned here. You are probably on 01.003, stock is 01.002. That's the closed source part which I think is more likely to be responsible for problems than the open source part of the custom firmware.
Could you try to change your Mobile Network Settings to "2G only"? After a modem restart / phone restart, I am usually able to send SMS via Chatty - but only that way (O2Germany Sim Card).
(10-25-2021, 08:44 AM)kqlnut Wrote: You can find the instructions to revert to the stock firmware here in biktorgj's repo.
GREAT!
Thank you!
(10-25-2021, 09:45 AM)arno_nuehm Wrote: Could you try to change your Mobile Network Settings to "2G only"? After a modem restart / phone restart, I am usually able to send SMS via Chatty - but only that way (O2Germany Sim Card).
Yes, that works. I am with O2 Germany, too.
But since I followed the steps described here I am permanently able to send messages.
Hi kqlnut ,
sorry, I did not manage to follow @biktorgj 's instructions - I got stuck after the second step.
This is what I did:
mobian@mobian:~/Downloads$ git clone --depth=1 https://github.com/Biktorgj/quectel_eg25_recovery
mobian@mobian:~/Downloads/quectel_eg25_recovery/update$ fastboot flash system mdm9607-sysfs.ubi
< waiting for any device >
Unfortunately, the "waiting for any device" does not end.
What did I do wrong?
(10-30-2021, 12:34 AM)AntonReiser Wrote: What did I do wrong?
I'm not sure, but perhaps you need to enter fastboot mode first. You could try to do it like in the flashall script und just exchange the flashing commands. But you would probably be better off asking directly on the bug tracker of the Github repo.
Also take note of the troubleshooting doc which also explains how to enter fastboot mode.
(10-30-2021, 12:34 AM)AntonReiser Wrote: Unfortunately, the "waiting for any device" does not end.
adb server has to be started as root. You are issuing the commands as user.
If you use the flash script you have to use sudo. Otherwise it will fail, since there are sudo commands in there
(11-01-2021, 05:29 AM)fernando_c_m Wrote: adb server has to be started as root. You are issuing the commands as user.
Thank you, kqlnut , fernando_c_m !
That made it work. My problem appears to be solved, the modem only crashed once over the past two days.
  Chatty Matrix Decryption Key jojuma 2 399 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 1,103 11-12-2023, 02:10 AM
Last Post: user641
  gnome-control-center: segmentation fault on startup jojuma 4 1,273 09-12-2023, 08:49 AM
Last Post: jojuma
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,300 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 2,072 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 2,026 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,333 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 5,308 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  beware chatty 0.7.0~rc0-1 treebeard 6 2,810 11-06-2022, 04:51 PM
Last Post: treebeard
Exclamation The webcam doesn't work in Firefox anonymous 0 791 11-06-2022, 01:45 PM
Last Post: anonymous
