ROCKPro64 sometimes doesn't Power On
A few months back I received my ROCKPro64 (4GB, v2.1) with aluminum case, RTC coin- battery holder, and 5A power supply. Everything is assembled and looks to run okay, most of the time. Except the board experiences an intermittent problem where the power button sometimes fails to start the machine, requiring several presses before any electrical activity. Other times it works like a charm. This can happen no matter which micro SD card is inserted, or even when I try a power-on with an empty reader. The button itself looks to be mechanically sound since the operating system never fails trap a shutdown press. I've since tried several different Linux distros on verified cards with no difference. Before giving my ROCKPro64 an unplanned early retirement, I was advised to register on the forums in case this has been solved. I've gone through the search facility but the hits didn't match my problem exactly.
welcome to the forum.
I have the same issue. But did not succeed to find a proper explanation. see this post : https://forum.pine64.org/showthread.php?...1#pid93571
(08-23-2021, 02:09 PM)LMM Wrote: Hi,
I have to push both power and reset.
But it only happens when I want to power on just after power off.
(08-23-2021, 02:09 PM)Hello, and thank you...At least it feels good knowing my copy isn't defective—relatively speaking. Since a few usersl have been asking about sundry power issues with their ROCKPro64, I'll assume it's a harmless but annoying quirk. Your reset and power suggestions seems to do the trick. Thanks again for your valuable pointers.LMM Wrote: Hi,
  Installing Wifi drive for the RockPro64 John45595 0 319 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 9,460 12-04-2023, 12:14 PM
Last Post: ok38
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 769 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 689 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,274 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 899 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,334 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,835 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,670 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,023 01-27-2023, 07:43 PM
Last Post: Spater
