Pine64 + waveshare display?
Rainbow
I've got a waveshare display 5" which I used with my Raspberry Pi 2. Now i'm wondering if someone has some experience to get this working on the pine64 since I've only got a blank screen without any image via the hdmi. On the Raspberry it was almost like plug-and-play with 'raspbian'.
I've got the display powered through the Pi 2 bus, ordered by the gpio layout and the layout on the display.  I do use the Ubuntu mate Image atm.
Is someone able to help me out and is prepared to share knowledge? ^^,
Hi! Did you read http://forum.pine64.org/showthread.php?tid=980 for switching resolutions? You have to make sure that the HDMI output matches something your display can support, I am not sure if your display's resolution is a supported mode atm... check here https://github.com/longsleep/sunxi-disp-...tput-names
(06-16-2016, 04:43 PM)iPhyse Wrote: I've got a waveshare display 5" which I used with my Raspberry Pi 2. Now i'm wondering if someone has some experience to get this working on the pine64 since I've only got a blank screen without any image via the hdmi. On the Raspberry it was almost like plug-and-play with 'raspbian'.
May able to use when the display siwtch in HDMI mode and please make sure that the  the display can accept 1080p input. This info just based on reading the link that you provided, and not guarantee will work.
(06-16-2016, 05:02 PM)xalius Wrote: Hi! Did you read http://forum.pine64.org/showthread.php?tid=980 for switching resolutions? You have to make sure that the HDMI output matches something your display can support, I am not sure if your display's resolution is a supported mode atm... check here https://github.com/longsleep/sunxi-disp-...tput-names
Thanks for your respond. But despite of your references the solution did not work for me, as so far. none of the both options won't display more than a black striped noise:
cat <<EOF| sudo tee -a /boot/uEnv.txt
optargs=disp.screen0_output_mode=480p //or i
EOF
sunxi-disp-tool switch -mode 0
sunxi-disp-tool switch -mode 2
But the strange thing is that the pi just works straight ahead..
If I take a view to the config, which are available on the rpi2, the /boot/config.txt would give me the opportunity to set some config according to my hdmi output for my display..
#hdmi_force_hotplug=1 //disabled
hdmi_group=2
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
resolution 800 x 480,
refresh 60Hz,
aspect ratio 15:9,
no margins,
no interlace,
normal blanking
It doesn't even matter to me if the touch function is working or not.. But only a output to the display is enough Smile
EOF
hdmi_group=2
hdmi_mode=87
refresh 60Hz,
aspect ratio 15:9,
no margins,
no interlace,
normal blanking
i have the same problem. can someone help steer me the right way
Question External storage problem for pine64 Dani6102 4 1,756 08-22-2023, 08:36 AM
Last Post: gulshan212
  Pine64 as wireless audio device S265 3 3,315 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,168 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,920 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,141 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,790 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,982 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,850 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,621 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 7,304 05-03-2019, 02:48 PM
Last Post: Mendota
