Pinebook Pro Docking Deck Ethernet Port
Good day everyone.
I'm in need of some assistance.  I have my pinebook pro attached to the Pine 64 docking deck and having some trouble with the deck's ethernet port.  I have USB-C power going into the docking deck along with an external HDMI monitor plugged into the HDMI port. I then have the deck's ethernet port connected to my network switch.  The problem i'm haviing is that when I power up the pinebook pro, the ethernet port doesn't activate and connect to my network.  This happens more time then not.  Once in awhile it will connect on power up, but mostly I will put the pinebook to sleep and then wake it up and then the ethernet port will activate.  Does anyone have a solution?  Thanks.
/Mike
Hey there! I-m having the exact same issue with the ethernet port and the docking deck, have you found a solution yet?, Btw have you tried the audio jack in the docking deck?, I can't make it work, so I wonder if the two issues are related.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 626 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 358 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 304 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 646 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,145 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,155 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,086 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,501 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,561 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,934 10-21-2022, 07:57 AM
Last Post: dachalife
