Keyboard issue: Debian
I'm a new Linux user and I've had a PinebookPro for several months now, using the Manjaro KDE that it came with.  It's been great, and I'm lucky to not have any issues aside from a not so smooth trackpad.
I just flashed Debian onto an SD card, and it loaded fine, and I updated it.  However, I have some keyboard issues that aren't present when I'm using Manjaro.  I wonder if anyone else has had this problem with Debian?
Certain key functions are not accurate.  Here are some examples:
1.  When I try to do the | (pipe) key, it will do ~ (tilde) instead.
2.  @ will do "
3.  # will do some other obscure symbol not even on the keyboard
4.  ~ will also do another obscure symbol.
Everything else on the keyboard works fine in Debian, at least from what I've tried.  Anyone else have this issue or have any ideas on how I can resolve it?
Thank you
You either have an ANSI keyboard, but settings for UK English, or an ISO keyboard, but settings for USA English.
(01-31-2021, 11:33 PM)KC9UDX Wrote: You either have an ANSI keyboard, but settings for UK English, or an ISO keyboard, but settings for USA English.
aaaahhh!  You're right.  I just looked at the keyboard setting.  On first startup of Debian it didn't go through initial set up process.  I'm guessing it doesn't do that on SD images?
Well anyway, you've solved my puzzle.  Thank you!
Correct. You don't get an installer, you get the installed system. So whomever made the image made an assumption about the keyboard. At one time, all PBPs had ISO keyboards, so it was a safe assumption.
This is the Debian problem. The Manjaro problem is that it changes your keyboard to Catalan after installation, before log in with hidden password!
(02-01-2021, 12:21 AM)KC9UDX Wrote: This is the Debian problem.  The Manjaro problem is that it changes your keyboard to Catalan after installation, before log in with hidden password!
Yikes! That's 100x worse!  Lucky my Manjaro was okay when I first received it.
Yes! That's how many of us received them. Set up in English, reboot, can't type the password, don't know why. The ******* password is all the wrong letters! A=K, B=R, C=O, etc.
(02-01-2021, 07:27 PM)KC9UDX Wrote: Yes!  That's how many of us received them. Set up in English, reboot, can't type the password, don't know why.  The ******* password is all the wrong letters!  A=K, B=R, C=O, etc.
How were you able to fix it?
"Thinking out of the box"
I put the cursor into the username field, and typed every key until I could find the ones with the letters in the password. Smile
(02-01-2021, 08:23 PM)KC9UDX Wrote: "Thinking out of the box"
Genius Idea
  Debian on Pinebook Pro u974615 7 1,058 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,059 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,452 09-07-2023, 09:38 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 776 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 978 08-18-2023, 01:58 AM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,072 07-15-2023, 02:58 PM
Last Post: u974615
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 1,341 05-10-2023, 04:51 AM
Last Post: Vinay
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,280 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,345 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,051 10-19-2022, 03:09 AM
Last Post: alpopa
