09-04-2020, 07:33 PM
(This post was last modified: 09-12-2020, 01:07 PM by ragreenburg.)
What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way?
Does anyone know where the scale to fit information is store?
09-05-2020, 04:54 PM
(09-04-2020, 07:33 PM)ragreenburg Wrote: What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way? https://source.puri.sm/Librem5/phoc/-/bl...to-fit#L26
09-05-2020, 06:58 PM
(09-05-2020, 04:54 PM)spaetz Wrote:Sorry, I should have been more clear. I mean store on the phone. I looked at their script and it has a path in it that I certainly can't find on Mobian of /sm/Puri/phoc/application/(09-04-2020, 07:33 PM)ragreenburg Wrote: What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way?
09-06-2020, 08:26 AM
(09-05-2020, 06:58 PM)ragreenburg Wrote:Yes, it uses gsettings (the equivalent of the windows registry) and you can get and set these entries using the command I linked above. It *is* where scale-to-fit save the info as the list is part of the scale-to-fit source.(09-05-2020, 04:54 PM)spaetz Wrote:Sorry, I should have been more clear. I mean store on the phone. I looked at their script and it has a path in it that I certainly can't find on Mobian of /sm/Puri/phoc/application/(09-04-2020, 07:33 PM)ragreenburg Wrote: What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way?
09-06-2020, 10:54 AM
(09-06-2020, 08:26 AM)spaetz Wrote:I am still a bit confused on where I can find this information on my phone though. Because I made an app that scales everything but realized that without being able to check and see if they are already scaled it'd be impossible for it to know what is and isn't scaled.(09-05-2020, 06:58 PM)ragreenburg Wrote:Yes, it uses gsettings (the equivalent of the windows registry) and you can get and set these entries using the command I linked above. It *is* where scale-to-fit save the info as the list is part of the scale-to-fit source.(09-05-2020, 04:54 PM)spaetz Wrote:Sorry, I should have been more clear. I mean store on the phone. I looked at their script and it has a path in it that I certainly can't find on Mobian of /sm/Puri/phoc/application/(09-04-2020, 07:33 PM)ragreenburg Wrote: What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way?
09-11-2020, 09:45 AM
(09-06-2020, 10:54 AM)ragreenburg Wrote:The best way I've found to check the scale-to-fit settings is to use the dconf Editor application. Open the app and navigate to sm/puri/phoc/application, then you'll see a list of applications, and you can check each individually to see if scale-to-fit is set to "true" or "false" (you can also change the setting this way, rather than using the command line).(09-06-2020, 08:26 AM)spaetz Wrote:I am still a bit confused on where I can find this information on my phone though. Because I made an app that scales everything but realized that without being able to check and see if they are already scaled it'd be impossible for it to know what is and isn't scaled.(09-05-2020, 06:58 PM)ragreenburg Wrote:Yes, it uses gsettings (the equivalent of the windows registry) and you can get and set these entries using the command I linked above. It *is* where scale-to-fit save the info as the list is part of the scale-to-fit source.(09-05-2020, 04:54 PM)spaetz Wrote:Sorry, I should have been more clear. I mean store on the phone. I looked at their script and it has a path in it that I certainly can't find on Mobian of /sm/Puri/phoc/application/(09-04-2020, 07:33 PM)ragreenburg Wrote: What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way?
09-11-2020, 10:03 AM
(09-06-2020, 10:54 AM)ragreenburg Wrote:(09-06-2020, 08:26 AM)spaetz Wrote:I am still a bit confused on where I can find this information on my phone though. Because I made an app that scales everything but realized that without being able to check and see if they are already scaled it'd be impossible for it to know what is and isn't scaled.(09-05-2020, 06:58 PM)ragreenburg Wrote:Yes, it uses gsettings (the equivalent of the windows registry) and you can get and set these entries using the command I linked above. It *is* where scale-to-fit save the info as the list is part of the scale-to-fit source.(09-05-2020, 04:54 PM)spaetz Wrote:Sorry, I should have been more clear. I mean store on the phone. I looked at their script and it has a path in it that I certainly can't find on Mobian of /sm/Puri/phoc/application/(09-04-2020, 07:33 PM)ragreenburg Wrote: What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way? You should be able to check the value using dconf, such as: Code: sundog@sundog-pinephone-lxde-emmc:~$ dconf read /sm/puri/phoc/application/firefox-esr/scale-to-fit Also, Code: dconf dump /
A64, SOPINE, Rock64, RockPro64, Pinebook1080p, Pinebook Pro, Pinephone, Pinewatch dev kit, Pinetab, Pinecil, Pinenut, Quartz64, Pinephone Pro, and PineNote (so far)
09-11-2020, 10:27 AM
[quote pid='77464' dateline='1599840207']
Also, Code: dconf dump / [/quote] Hey, that's cool, thanks @sundog ! Simpler than using dconf Editor, especially if you narrow it down to just phoc: Code: dconf dump /sm/puri/phoc/
09-12-2020, 01:10 PM
(09-11-2020, 10:27 AM)DarkManiels Wrote: [quote pid='77464' dateline='1599840207'] Hey, that's cool, thanks @sundog ! Simpler than using dconf Editor, especially if you narrow it down to just phoc: Code: dconf dump /sm/puri/phoc/ [/quote] Thank you for that! I'm a few years into using Linux and still learning tons of new stuff. I appreciate the help! |
Make scale setting persistent | 3x5co | 2 | 2,234 |
10-26-2021, 05:57 PM Last Post: 3x5co |
Software store crashes | LMalilil | 3 | 4,602 |
09-28-2020, 10:13 AM Last Post: ThrillGates |
Global scale-to-fit? | DarkManiels | 5 | 7,835 |
09-03-2020, 05:02 PM Last Post: DarkManiels |
anyone notice that scale-to-fit works on some apps, but not others? | arturo2bodegas | 1 | 2,860 |
08-01-2020, 10:58 AM Last Post: bcnaz |
Video output scale after update 14/07/2020 | antiX-Dave | 3 | 4,771 |
07-16-2020, 04:32 AM Last Post: a-wai |
