Software store crashes
I haven’t been able to use the software store in a couple weeks now. Crashes as soon as I go to updates or try to search categories for apps. I see people talking about this megapixels app that was apparently included in the nightly build a couple nights ago but it’s not on my phone. Does updating from CLI not update the OS as well? That’s the only way I have been able to get any updates
(09-24-2020, 02:50 AM)LMalilil Wrote: I haven’t been able to use the software store in a couple weeks now. Crashes as soon as I go to updates or try to search categories for apps. I see people talking about this megapixels app that was apparently included in the nightly build a couple nights ago but it’s not on my phone. Does updating from CLI not update the OS as well? That’s the only way I have been able to get any updates
I had to install it manually:
apt install megapixels
Thanks. That’s what I ended up doing as well. Managed to get the software store to work but I have to go to my installed apps first before selecting the updates tab. If I click straight on the updates tab as soon as I open the store it crashes. If I go the other route I’m able to update through the store
(09-24-2020, 09:47 PM)LMalilil Wrote: Managed to get the software store to work but I have to go to my installed apps first before selecting the updates tab. If I click straight on the updates tab as soon as I open the store it crashes. If I go the other route I’m able to update through the store
Actual good advice to keep the software store from crashing. I gave up on the software store early on because of this issue. I find it much more consistent and informative to upgrade from CLI anyway. I recommend giving it a try test your own preferences.
For Debian-based distros (e.g. Mobian, UBports, PureOS):
sudo apt update && sudo apt upgrade
For Arch-based distros (e.g. PMOS, Manjaro):
sudo pacman -Syyu
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 553 08-30-2023, 03:23 PM
Last Post: jojuma
  PinePhone won't boot after software update jb2000 2 1,248 03-17-2023, 07:26 AM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,335 10-14-2022, 05:38 PM
Last Post: Krafter
  Software update missing on desktop MikeMan 1 1,400 01-27-2022, 06:10 AM
Last Post: bcnaz
  Software/Notifications battlegarden 4 3,995 05-01-2021, 03:22 PM
Last Post: MtnSk8
  Is there a list of software/Hardware errors Franze_m 6 4,986 02-24-2021, 12:07 PM
  software crashes when selecting any category RodneyMyers 13 13,808 01-25-2021, 06:14 AM
Last Post: Codenul
  Geary crashes during start after recent update p1trson 2 3,351 01-16-2021, 04:49 AM
Last Post: p1trson
  Gnome Software crashing Concrete_panda 4 9,186 12-13-2020, 07:06 PM
  Application "Software" crashes when i tap on any category User 20385 0 1,657 11-20-2020, 03:59 AM
Last Post: User 20385
