Orange light won't boot>>>PineBook Pro
Dodgy I get a new Pinebook Pro like a month ago run ok, then after did the first update, all seem ok, turn it off. The next day when I turn it on the orange light never turns green and a black screen there, won't do anything. What to do send it back and ask for my money or do Pine64 have any kind of customer technical support for these types of issues. I ask because I can't find anything to help me fix this issue. The only support to be found will be of course sales support. Please get back to me thank you! Dodgy
(07-10-2020, 10:43 AM)user1gokou Wrote: Dodgy I get a new Pinebook Pro like a month ago run ok, then after did the first update, all seem ok, turn it off. The next day when I turn it on the orange light never turns green and a black screen there, won't do anything. What to do send it back and ask for my money or do Pine64 have any kind of customer technical support for these types of issues. I ask because I can't find anything to help me fix this issue. The only support to be found will be of course sales support. Please get back to me thank you! Dodgy
There is no technical support outside of hardware faults. Try searching the forums for similar issues posted/marked solved.
You bought a computer that was designed for people who can deal with this sort of problem; I thought that was pretty obvious when I bought mine.
Have you tried leaving it on? I don't know what OS you're using, but sometimes booting takes a little longer. Else you'll need to either boot from an SD card to recover the system, or, reflash the eMMC with an adaptor in another computer.
I'm not sure if this is your particular issue, but I had at some point left a bootable SD card inside and forgot about it.
After a reboot I could not boot my device. I only found out about it because i wanted to boot from another SD card that I found out
there was already one inside it :facepalm:
(07-10-2020, 02:49 PM)devrtz Wrote: I'm not sure if this is your particular issue, but I had at some point left a bootable SD card inside and forgot about it.
Well, it's a good thing to be aware of.  So, thank you.
  Pinebook Pro Initial Impressions kunger 443 590,245 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,301 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 403 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 305 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 293 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 228 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 680 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 749 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 847 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 296 01-16-2024, 09:17 AM
Last Post: jbradley419
