Updated board, still have USB C charging problem
I cannot get my pinephone to charge well unless it's off. It was originally a UBports CE, but I updated to the increased RAM board using the discount provided.
Using an appropriately spec'ed charger, it drops to like 0.5 Amps when turned on. No difference between this board and the old. Kind of disappointing because this was advertised as the fix and I shelled out another $70 for it
(01-29-2021, 07:37 PM)xonq Wrote: I cannot get my pinephone to charge well unless it's off. It was originally a UBports CE, but I updated to the increased RAM board using the discount provided.
Did you flash the Anx firmware? It's in the wiki
I had a lot of trouble with the USB-C connector which I eventually discovered was making/breaking charge connection. The replacement USB-C board appears very weak also.
If "an appropriately spec'ed charger" means one using Power Delivery you probably need both the ANX firmware as mentioned above, and an appropriately up to date kernel, which AFAIK not all the distros have. I think Megous has the most up to date details:
https://xnux.eu/devices/feature/anx7688.html
https://xnux.eu/news.html
yes, via method 2
(01-30-2021, 09:13 AM)wibble Wrote: If "an appropriately spec'ed charger" means one using Power Delivery you probably need both the ANX firmware as mentioned above, and an appropriately up to date kernel, which AFAIK not all the distros have. I think Megous has the most up to date details:
it's an ipad charger A1401, perhaps I'm wrong about PD on this. 5.3 V at 2.4 Amps. Charge at 0.5 Amps. Using Manjaro Phosh B5
Is it also 0.5 A if you plug it in after the phone is on?
(01-30-2021, 12:10 PM)desca Wrote: Is it also 0.5 A if you plug it in after the phone is on?
it is 0.5A only when on, I believe fine off.
so my dock receives power from my monitor, which is on 5V 4A power supply. i believe the dock has PD because im able to charge at 3A. so it appears I was wrong about power supply. my understanding is the correct V is important, but the phone can regulate the amperage, so 4A shouldnt be a problem, correct? (phone says drawing 3A)
next q, though, i hear a persistent buzzing sound when connected to the dock. this concerns me as Im wondering why it only does this when fast charging. also there's a bunch of weird activity on the phone when this happens but i dont think its possible to deconvolute it from convergence causing a bunch of problems.
  Updated Physical Keyboard? jakfish 1 238 05-13-2024, 03:01 PM
  Pine phone main board part Generaltuxenburg 1 1,135 07-31-2023, 07:50 PM
  USB C side board out of stock gab 3 1,964 12-29-2022, 11:42 AM
Last Post: fxc
  What Adhesive to buy for daughter board? LogosCoder 1 1,086 11-28-2022, 05:07 PM
  Charging Indicator On - Not Charging SJSEng 0 820 08-30-2022, 07:33 AM
Last Post: SJSEng
  PPKB with phone; phone dies while charging SwordfishII 1 1,425 06-08-2022, 04:14 AM
Last Post: SwordfishII
  Battery mot charging past 54% StickyPine 32 26,964 02-26-2022, 02:07 AM
Last Post: vusra
  Pinephone time goes too slow (not a 2115 year problem) grwlf 1 1,725 02-06-2022, 05:05 AM
Last Post: grwlf
  pinephone circuit board design, conductive parts zetabeta 1 1,887 08-12-2021, 05:28 AM
Last Post: wibble
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 1,769 06-22-2021, 10:03 AM
