Anbox for Debian
Has anyone been able to get keyboard input working yet?
(07-06-2020, 05:33 AM)Id405 Wrote: Has anyone been able to get keyboard input working yet?
It appears to be an issue with the virtual keyboard rather than anbox itself - squeekboard seems to map keys in an odd way for some desktop apps, see this issue:
https://source.puri.sm/Librem5/squeekboard/-/issues/168
I get error messages when I try to install the anbox kernel modules to Kernel 5.7. Is there a solution for that problem?
(07-17-2020, 02:01 AM)Transistor4acpu Wrote: I get error messages when I try to install the anbox kernel modules to Kernel 5.7. Is there a solution for that problem?
See:
(06-25-2020, 06:38 AM)tophneal Wrote: This has been brought up in the Anbox github issues, and there is a solution that isn't reverting your kernel version. ashmem and binder are now part of mainline kernel, and can be enabled to allow for installation: https://github.com/anbox/anbox-modules/i...-643728906 Just recompile your kernel and enable the flags. Someone was kind enough to update the Arch wiki page with the now necessary steps: https://wiki.archlinux.org/index.php/Anbox
Apparently, you'll want to remove any previous installation attempts first.
You need to rebuild the kernel with those flags enabled.
What error messages and which distro are using? Pretty sure it was working in mobian but I haven't tested it for a while.
Apparently the anbox modules are now upstream (and previous version can't be built with 5.7), so we need to provide a build which includes these as default.
This should happen within a few days, don't worry Wink
Latest kernel now includes binder and ashmem, you should be able to run anbox again.
Thanks for the help and the Kernel.
But how do I install anbox? apt install anbox don't work and I can't install it with snapd.
#19
This is frustrating, for sure...looks like it's targeted towards ubuntu systems, but ubuntu is built on debian...I've got snap installed, and got the anbox-installer snap installed, but it seems that maybe that's deprecated now? I cloned the anbox git and tried to compile it from source, but I just don't have the linux skills (yet). C compiler is throwing up errors...but maybe it shouldn't be necessary to build from source? I don't know. I can tell you that you won't find an anbox .deb in the repos, so I wouldn't bother with apt.
#20
(07-22-2020, 02:35 PM)Transistor4acpu Wrote: But how do I install anbox? apt install anbox don't work
Looks like you have to add contrib to /etc/apt/sources.list for apt install to work but there appears to be a further problem with modprobe failing to find binder or ashmem in the kernel modules directory. I'm guessing there's a further step beyond enabling them in the kernel?
  atinout binaries for mobian/debian? NeutralGrey 2 283 05-13-2024, 02:42 PM
Last Post: Gumur
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 3,089 08-31-2023, 12:38 PM
Last Post: vusra
  Debian bookworm security repo user641 2 1,702 02-17-2023, 01:12 AM
Last Post: user641
  Gnome-podcasts on Debian repos user641 4 3,161 02-06-2022, 04:58 AM
Last Post: jsch
  gnome podcasts on debian repo, dino-mobile user641 3 3,402 09-11-2021, 12:04 AM
Last Post: user641
  Best/easiest way to install minimal Debian on PinePhone? mcgee 6 5,688 07-18-2021, 09:35 AM
Last Post: swiley
  How does calls work in debian? temp0rary 4 4,425 05-31-2021, 10:44 AM
Last Post: temp0rary
  Whatsapp in Anbox scott_VYuCAbn3k1NFK 7 9,389 03-22-2021, 08:46 AM
Last Post: Skyrrd
  Debian/Mobian packaging help needed arno_nuehm 1 2,280 03-20-2021, 04:59 PM
Last Post: TRS-80
  Anbox apps listed in the launch screen mark1250 1 2,854 03-17-2021, 02:23 PM
Last Post: tvall
