Anbox apps listed in the launch screen
Is there a way to stop the apps that are installed in anbox from showing up in the app launcher screen? I've deleted the .desktop files from /home/mobian/.local/share/applications/anbox directory, but they are eventually recreated.
It's confusing to have 2 Settings apps.
Thanks.
Mark
(03-17-2021, 11:38 AM)mark1250 Wrote: Is there a way to stop the apps that are installed in anbox from showing up in the app launcher screen? I've deleted the .desktop files from /home/mobian/.local/share/applications/anbox directory, but they are eventually recreated.
Thanks.
Mark
you could use the purism anbox fork which has a patch to disable it, or just use their patch on the debian version. both involve recompiling anbox.
https://source.puri.sm/Librem5/debs/anbo...awer.patch
or if you want to trust a stranger on the internet, heres a deb or the debian version with that patch applied https://tvall43.ddns.net/stuffs/anbox_0...._arm64.deb
  Keyboard not popping up on QT apps 3x5co 1 224 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 265 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 643 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,082 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,206 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,006 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,496 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,769 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,229 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 843 07-17-2022, 10:34 AM
Last Post: 3x5co
