Following on from this post, here's a recap and some extra info.
Install the anbox modules: [ Edit: No longer required from kernel 5.7 so read this post ]
Download anbox-image-working.tar.gz from here - extract android.img and ignore the other files.
Get the services and frontend started:
Download an app and install it, eg bbc news app
App loads but no internet? The below should help once the kernel supports ip routing:
You may want to modify the android image, e.g. to support the microg app suite as discussed here. Someone has already provided a patched services.jar - download it from here. Following instructions are taken from here.
Uncompress filesystem:
Copy over patched file:
Recompress to image:
I haven't found any use for it but the microg self-test says it works.
Okay, that should be about it - except sound might not work. See this discussion but the media xml files are present in this image so maybe it's a permission issue. Anyway, have a play with it and see whether it works for you.
sudo apt install dkms
git clone https://github.com/anbox/anbox-modules
cd anbox-modules
sudo cp anbox.conf /etc/modules-load.d/
sudo cp 99-anbox.rules /lib/udev/rules.d/
sudo cp -rT ashmem /usr/src/anbox-ashmem-1
sudo cp -rT binder /usr/src/anbox-binder-1
sudo dkms install anbox-ashmem/1
sudo dkms install anbox-binder/1
sudo apt install anbox android-tools-adb
sudo cp android.img /var/lib/anbox/
sudo systemctl start anbox-container-manager.service
systemctl --user start anbox-session-manager.service
anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
adb install InsertAppName.apk
sudo /usr/share/anbox/anbox-shell.sh
su
ip route add default dev eth0 via 192.168.250.1
ip rule add pref 32766 table main
ip rule add pref 32767 table local
sudo apt install squashfs-tools
mkdir ~/anbox-work
cd ~/anbox-work
cp /var/lib/anbox//android.img .
sudo unsquashfs android.img
sudo cp ./services.jar ~/anbox-work/squashfs-root/system/framework/
cd ~/anbox-work/squashfs-root/system/framework/
sudo chown -R 100000:100000 services.jar
cd ~/anbox-work
rm android.img
sudo mksquashfs squashfs-root android.img -b 131072 -comp xz
