Manjaro ARM 20.02 released
I just want to put it out there that there's a new release of Manjaro available. You can't just upgrade to it if you're on Manjaro 19 - you have to do a clean install. OpenGL 2.0 can be activated on the KDE version for what I understand to be hardware video acceleration. Laptop now goes to sleep when you close the lid (sometimes). Just to warn you though - my KDE version won't boot anymore either from emmc or from on SD card. I have XFCE on the internal storage of a different Pinebook Pro though and that's working very nicely. Etcher won't install on it though. Download speed on Firefox is about 11ms ping and 80 Mbs download speed. Slightly faster on Chromium. I haven't run any benchmarks yet.
Here's the link:
https://forum.manjaro.org/t/manjaro-arm-...sed/125823
You can update to this from a 19.X version, but you will need to make sure you install the newer pacman-mirrorlist package.
I had issues boot wise too, my thinking was my 2.0 and 1.9 uboot.img so I down graded to earlier uboot from Mrfixit github and all worked fine booting. Just my two cents. I flashed my Emmc originally with Debian latest before installing Manjaro I think Debian writes latest uboot via mrfixit_update.sh so maybe try down grading uboot before throwing the towel.
Ne quid nimis
20.04 came out today and Manjaro recommends a fresh install because of underlying things they changed including the partition layout. https://forum.manjaro.org/t/manjaro-arm-...sed/133374
Cool beans installing now.Thanks
Sent from my iPhone using Tapatalk
Ne quid nimis
Thumbs Up
(04-02-2020, 04:34 PM)Damon Wrote: 20.04 came out today and Manjaro recommends a fresh install because of underlying things they changed including the partition layout. https://forum.manjaro.org/t/manjaro-arm-...sed/133374
I see that. Great! Now that 20.04 is out this thread is no longer relevant. I'll try to delete the whole thread soon.
Edit: I've just marked the issue as solved instead.
  Manjaro Sway Theme Broken Eighty8 1 458 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,885 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 490 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,431 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,566 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 552 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 1,111 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,119 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,101 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 901 08-18-2023, 02:06 AM
Last Post: juliamenendez
