[solved] On default OS (Debian 9), lxqt breaks Chromium
I tried to install lxqt on the default OS of the pinebook pro (Debian 9).
Firstly it's complicated: you have to install openbox in addition to task-lxqt-desktop, which doesn't install by default (!), And you have to go through lightdm-gtk-greeter-settings to add a session selector. In addition, the default configuration is very poor: there are almost no icons.
Second, lxqt modifies the chromium configuration folder, so that it is impossible to connect to your Google account, because the browser is not "secure" (!?)
Fortunately I had synchronize my profile in the Google cloud.
So to solve the problem:
mv ~/.config/chromium ~/.config/chromium.back
restart chromium
Chromium recreated a configuration folder.
Connection to Google is again possible.
Then I syncronized my profile, so I didn't lose my extensions nor everything else.
I just had a security alert that a "new" browser had logged into my account, but obviously it was myself.
Pinebook Pro, standard config (Manjaro)
  Official Debian support moonwalkers 63 53,932 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,637 03-31-2024, 10:11 AM
Last Post: u974615
  Nethunter default password failed lamlarryyyy 0 453 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,305 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,914 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,330 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,346 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,464 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,206 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 2,040 09-23-2022, 08:37 PM
Last Post: computerc
