The issue is observable only with fbturbo - it treats all displays as the default one. If you disable it and run just Panfrost, everything is picked up as expected.
There are a few threads for Raspberry Pi that make adjustment directly to `/etc/X11/xorg.conf.d/99-fbturbo.conf` to manually set the monitor setup. My attempts to use a few of those instructions didn't produce satisfactory results.
On ayufan's and mrfixit's builds I can't see such shenanigans with fbturbo.conf. There should be something else for fbturbo to behave normally with multi-monitor setup that I'm missing.
Hello Wim,
wvdschel
As your PM is disabled. Here is the answer.
Thank you for taking interest in Manjaro Arm.
Ko-Fi does not take a cut at all and is designed for one-off donations:
https://help.ko-fi.com/hc/en-us/articles...yments-FAQ
So Please use Ko-Fi for your one-time donation.
Cheers.
Thanks.
Manjaro ARM Team.
12-07-2019, 08:38 PM
(This post was last modified: 12-08-2019, 01:35 AM by Der Geist der Maschine.
Edit Reason: typos, gcin
I run Manjaro xfce off a micro SD card (I started with Preview 3 and keep the packages up to date). I decided to keep Manjaro as my secondary OS as the kernel is rock-stable and userland is 64bit. I started to set it up and feel I'm in the dark Linux ages, again:
- I don't find a GUI setting to turn off the screen after some idle time. All GUI settings just turn the screen black, but not off. Currently, I use xset to manually turn off the screen, e.g.
$ xset dpms force off
- When I ssh -Y into another machine and start emacs remotely, no single font is found. I then installed the 75dpi and 100dpi fonts and needed to manually set +fp /usr/share/fonts/75dpi/ and set +fp /usr/share/fonts/100dpi/. I can't remember the last time I needed to deal with fonts. Shouldn't the fp paths be set automatically by the package manager?
- Manjaro is a rolling release distribution. Some software seems to roll faster than other:
$ /usr/bin/xfce4-screensaver
/usr/bin/xfce4-screensaver: error while loading shared libraries: libxfconf-0.so.2: cannot open shared object file: No such file or directory
The more recent version libxfconf-0.so.3 version is installed. Both seem to be compatible and a soft link fixes the problem
# ln -s /usr/lib/libxfconf-0.so.3.0.0 /usr/lib/libxfconf-0.so.2
- Similar problem with tumblerd (log from systemd journal). Why aren't dependencies automatically installed?
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-ffmpeg-thumbnailer.so": libffmpegthumbnailer.so.4: cannot open shared object file: No such file or directory
Dec 07 18:26:04 manjaro dbus-daemon[971]: [session uid=1000 pid=971] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-poppler-thumbnailer.so": libpoppler-glib.so.8: cannot open shared object file: No such file or directory
Dec 07 18:26:04 manjaro org.freedesktop.thumbnails.Thumbnailer1[971]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-raw-thumbnailer.so": libopenrawgnome.so.7: cannot open shared object file: No such file or directory
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-odf-thumbnailer.so": libgsf-1.so.114: cannot open shared object file: No such file or directory
- gcin always crashes when clicking on its panel icon
Dec 07 23:30:20 manjaro systemd-coredump[1823724]: Process 1822296 (gcin) of user 1000 dumped core.
Stack trace of thread 1822296:
#0 0x0000aaaaccbf8914 n/a (gcin + 0x10914)
#1 0x0000ffffa5c7bff8 g_closure_invoke (libgobject-2.0.so.0 + 0x15ff8)
#2 0x0000ffffa5c93a00 n/a (libgobject-2.0.so.0 + 0x2da00)
#3 0x0000ffffa5c9ce28 g_signal_emit_valist (libgobject-2.0.so.0 + 0x36e28)
#4 0x0000ffffa5c9d430 g_signal_emit (libgobject-2.0.so.0 + 0x37430)
#5 0x0000ffffa60133e4 n/a (libgtk-x11-2.0.so.0 + 0x1e33e4)
#6 0x0000ffffa60133e4 n/a (libgtk-x11-2.0.so.0 + 0x1e33e4)
#7 0x0000ffffa5f88bfc n/a (libgtk-x11-2.0.so.0 + 0x158bfc)
#8 0x0000ffffa5c7bff8 g_closure_invoke (libgobject-2.0.so.0 + 0x15ff8)
#9 0x0000fffff4913d58 n/a (n/a + 0x0)
- Firefox: Add-Ons: Plugins: "OpenH264 Video Codec provided by Cisco Systems, Inc. will be installed shortly." Shorty? I have an uptime of several days. Anyone not having this problem?
(12-10-2019, 07:13 AM)wvdschel Wrote: (12-07-2019, 06:41 AM)spikerguy Wrote: Hello Wim,
@wvdschel
Cheers.
Thanks.
Doh. I only noticed this message after I've made a donation using the Open Collective yesterday ![Sad Sad](https://forum.pine64.org/images/smilies/sad.png)
Are PMs off by default? I've never changed any setting, and can't seem to find it in the profile settings pages either at first glance.
It is ok to use Open Collective also. Thank you for your generous support.
Even I am not familiar with this forum settings. Please check in your profile.
Cheers.
Manjaro ARM Team.
(12-07-2019, 08:38 PM)Der Geist der Maschine Wrote: I run Manjaro xfce off a micro SD card (I started with Preview 3 and keep the packages up to date). I decided to keep Manjaro as my secondary OS as the kernel is rock-stable and userland is 64bit. I started to set it up and feel I'm in the dark Linux ages, again:
This is the kind of thing I believe to be SoP for ArchLinux and derivatives. I'm open to gentle correction, if I'm mistaken or out of date. Such manual configuration is what led Jamie Zawinski to quip, "Linux is free, only if your time is worthless", about 20 years ago. Relevant to this comment, Jamie is the originator and maintainer of the Xscreensaver collection!
Those years were excellent for learning *Nix systems, 'under the covers' in the day. I feel blessed by the advent of Debian and derivatives with package dependency management, /etc/alternatives, and protection for configuration file customization by the package manager.
— Jeremiah
— Jeremiah Cornelius
"Be the first person not to do something, that no one has thought of not doing before’’
