ROCKPRO64 PCI-E SATA is low price and low power best to choose wipe your hard disk
Wink
If your company or personal not use your old hard disk , but the hard disk data include have your privacy data from hard disk e.g ( Your medical treatment information , ID CARD Number , VISA CARD , PASSWORD   ), this time you need to wipe your hard disk by the US LAW (HIPAA) .
This is very basic level to clear up your include privacy data.
I think most people know delete file is not really deleted , so this need to use Rrockpro64  help.
For the new generation HardDisk over 2TB , you need is time time time and more time and electricity  to wipe your hard disk.
Yes , you can say physical destroy is very fast , easy and safe , but physical destroy tool very expensive .
I reseach some have hardware they just to run software wipe your hard disk.
1. http://www.mejw.com.tw/  TP100-I around USD $456   ( Support  4TB )
2. http://www.killdisk.com/killdesk.htm USD $1999   ( Support more than 4TB in size )
Debian arm64 , armhf open source software have ( Scrub , Nwipe  ) can wipe your hard disk.
( Note: This two software without warranty and any certification  ( e.g HIPAA, ISO27001/27002) ,  no guarantee your data is completely sanitized across the entire drive , but the same have wipe algorithm .)
At least recovery software can't find it privacy data
1. Scrub  ( wipe algorithm )
https://github.com/chaos/scrub
[Image: A4RIenN.png]
2. Nwipe  (Based on Dban )
https://github.com/martijnvanbrummelen/nwipe
[Image: 3Uf44fc.png]
Other:  Open source Dban need your x86 , x86-64 pc around 300 w Power to wipe your harddisk , very waste your money  .
Rockpro64 you have 1 usb3.0 , 1 PCI-E support 2  SATA port
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
why not just use dd?
(05-13-2018, 03:51 PM)dkryder Wrote: why not just use dd?
Why not just use my ryobi cordless drill and a 10mm metal bit.. it's much faster! Tongue
only dd  random to wipe your hard disk is not safe .   So why Dban was many people downloads: 14,121 This Week? why people need this ?
https://sourceforge.net/projects/dban/
And please search  NIST.SP.800-88r1.pdf  page 40 ( ATA Hard Disk Drives This includePATA, SATA, eSATA, etc ) for hard disk from google , this is usa security suggest to clear your hard disk  .
Yes you can , but your hard disk can't use again .............  2TB........you really want to waste your hard disk ?
what is unsafe about using dd to
dd if=/dev/zero of=/dev/sdX or something similar?
(05-14-2018, 02:25 AM)dkryder Wrote: what is unsafe about using dd to
To wipe properly you need to do a few wipes with random data...
How about the  0 x FF ?
Good wipe for hard disk is 0 , 1  , random  .
Big Grin
All jokes aside, this could indeed be a niche market for the rock64pro... wonder how long it will take before someone makes some sort of rock64pro-based hard drive erasing product with easy to use touchscreen for say US$129? Smile [ be warned, Joe mentioned the idea first, and I just turned it into a product, so we want royalties if someone does do that!  Angel  ] Big Grin Big Grin
(05-14-2018, 10:51 PM)pfeerick Wrote: All jokes aside, this could indeed be a niche market for the rock64pro... wonder how long it will take before someone makes some sort of rock64pro-based hard drive erasing product with easy to use touchscreen for say US$129? Smile [ be warned, Joe mentioned the idea first, and I just turned it into a product, so we want royalties if someone does do that!  Angel  ] Big Grin Big Grin
Yes this is  jokes , but  this is i saw at least 4 company to sales hardware wipe tool ,  very expensive.
basically this is wipe your hard disk  to protection your information just is level one.
level two is hard disk demagnetize , level three is physical destroy.
I think for home user use wipe software is enough , for company  wipe software is protection you send some where
e.g repair or destroy your hard disk prevent some people easily to recovery your information.
  power button not working Vista8720 0 327 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 389 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 10,036 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 123,546 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 857 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 742 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,451 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 954 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,409 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,934 03-19-2023, 06:22 AM
Last Post: runyor
