Power supply questions
#31
(05-06-2016, 01:24 AM)SkimMilk Wrote: I'm interested to know if a 18650 will work as a battery for the Pine too! Anyone?
User paulieg could answer that. In fact he already answered it. There's a search field in the upper right corner of this browser window and querying for 18650 will succeed for sure. Smile
#32
Thanks! Looking at that thread now.
#33
As for the connectors they are Micro JST the one for the 3.7v rechageable is a 3 pin and the one for the RTC battery is a 2 pin. Amazon has 2 pin but I didnt see 3 pin ones.
Ebay and aliexpress and mouser and maybe Jameco or Mcmelectronics etc.
#34
(05-02-2016, 09:31 AM)tmontero65 Wrote: Ok, thanks for the links and suggestions.  I think for the moment, I'll look at either getting a powered external hard drive, or a powered USB hub.  I did try plugging in my hard drive over the weekend, and while its light came on, it was making a clicking sound every few seconds, which I assume was from not enough power being available when it was trying to spin.  It didn't crash the board at least, so that was nice.
 Even when connecting an external HD to a computer, this is such a common problem that there are combo cables with a USB plug and a wall-wart power plug specifically for it. A possible problem with powered USB hubs is that they may limit the power output to each port (which is possibly the intent of the USB spec) and you could have the same under-powering problem. Of course there are also cases for bare HDs that have a separate power plug rather than are powered from USB.
#35
I really don't understand this stuff and I read some horror stories early on so I'm gonna double check with you guys. Based on what I've read here I think this is safe...
I have a power brick rated for Input: 5V/2.4A Max Output: 5V/5.8A Max
and USB cable style 20851 80 degrees 30V VW-1 26AWG/2C + 28AWG/2C
...unless I'm mistaken about Amplitude, this should work to power and charge the pine?
#36
(08-11-2017, 08:06 PM)mesaxi Wrote: I really don't understand this stuff and I read some horror stories early on so I'm gonna double check with you guys. Based on what I've read here I think this is safe...
Anyone know about this? I just don't really understand what it is that fries the board, too much power, too little power, or either.
#37
Prefer 22AWG cable due to cable resistance that cause voltage drop and impact PINE A64 board stability, here is the good article: https://electronics.stackexchange.com/qu...martphones.
  Pine64+ power button PaddyChan 0 2,862 09-14-2020, 09:55 AM
Last Post: PaddyChan
  UK power supply (Pinebook Pro 64) skobi 0 2,351 11-17-2019, 04:55 AM
Last Post: skobi
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 6,478 02-22-2019, 03:25 AM
Last Post: GaryFunk
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,829 05-24-2018, 01:58 AM
Last Post: crapped
  short boot time after power-up bongo 7 10,416 10-31-2017, 08:02 AM
Last Post: bongo
  PINE64/ROCK64 infra receiver power on cserem 1 3,679 10-06-2017, 07:25 AM
Last Post: MarkHaysHarris777
  Sufficient supply for product integration? SlowBro 4 6,608 02-19-2017, 10:40 AM
Last Post: dkryder
  Power-on pine by remote kleintvra 1 2,926 08-11-2016, 02:48 PM
  Chgled Power Reset rduerst 4 6,905 07-22-2016, 09:22 PM
Last Post: pfeerick
  Pine A64 not powering up / Power button missing vaevictis 10 14,444 07-06-2016, 01:28 PM
Last Post: xalius
