Supply DC power to Pine64 via Pi-2 Connector & Euler Bus?
The Pi-2 connector of Pine64 has Pin 2 & 4 labeled as "5V", and Pin 6, 9, 14, 20 as "GND".
The Euler bus connector has Pin 2 & 4 as "DC IN", and Pin 6, 9, 14, 20 as "GND".
So, questions:
1. Can I supply regulated 5V DC to power the whole board via Pin 2/4 of Pi-2 or Euler bus connectors?
2. Do these pins have the same 2A current rating as the micro USB power jack?
(05-23-2018, 03:49 PM)crapped Wrote: The Pi-2 connector of Pine64 has Pin 2 & 4 labeled as "5V", and Pin 6, 9, 14, 20 as "GND".
So, questions:
MicroUSB is only rated at 1.8A, and most microUSB connectors are hopeless. You are much better off using the euler or rPi headers for power.
The pins are more than up to the task, and if you are concerned, simply use two. You have two DC_IN pins and two GND pins in close proximity on the euler bus. I have powered the pine64 using the rPi header, but find the euler bus handier as it frees up the rpi header if you intend to put a hat or adapter on the rpi bus.
e.g. http://linux-sunxi.org/File:Pine64_Power...nector.jpg
(05-23-2018, 09:52 PM)pfeerick Wrote: MicroUSB is only rated at 1.8A, and most microUSB connectors are hopeless. You are much better off using the euler or rPi headers for power.
Thanks, your answer helps. I will save some money not buying micro USB cords, they are expensive.
Question External storage problem for pine64 Dani6102 4 1,754 08-22-2023, 08:36 AM
Last Post: gulshan212
  Jack connector problem pinebug 0 1,543 11-10-2022, 01:46 PM
Last Post: pinebug
  Pine64 as wireless audio device S265 3 3,305 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,165 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,885 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,136 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,788 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,975 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,848 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,613 11-25-2019, 12:19 PM
Last Post: Partymack711
