PINE64/ROCK64 infra receiver power on
On the PINE64 board there is an infra header. With the diode installed, is it capable of turning ON the board, or just turning it OFF?
I am interested in the answer for the ROCK64 board too, which has an infra receiver installed already: can it be used to power ON the device, or only to shut it down with the remote?
Thank you
(10-06-2017, 06:41 AM)cserem Wrote: On the PINE64 board there is an infra header. With the diode installed, is it capable of turning ON the board, or just turning it OFF?
On the PineA64 it may only be used to power OFF;  but it may NOT be used to power ON.  This is a restriction on the way the AXP803 ( PMIC ) works with the SoC & system.
On the Rock64 it 'may' be possible to power ON,  but the IR receiver so far has received very little attention;  out-of-box it does not work ( has no input device ) in linux;  does work in a limited way in Android.  In the future the IR receiver will get more attention I'm sure.
Blush
Question External storage problem for pine64 Dani6102 4 1,720 08-22-2023, 08:36 AM
Last Post: gulshan212
  Pine64 as wireless audio device S265 3 3,263 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,153 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,747 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,126 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,777 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,956 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,837 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,587 11-25-2019, 12:19 PM
Last Post: Partymack711
  UK power supply (Pinebook Pro 64) skobi 0 2,303 11-17-2019, 04:55 AM
Last Post: skobi
