Sufficient supply for product integration?
I emailed the company earlier this week and haven't gotten a reply. What is the expectations from the company about being able to supply in bulk for product integration? I likely won't need a lot of supply; maybe 2000-5000 per year. But I do want to know this before I proceed down the road of using the Pine.
(02-17-2017, 10:31 AM)SlowBro Wrote: I emailed the company earlier this week and haven't gotten a reply. What is the expectations from the company about being able to supply in bulk for product integration? I likely won't need a lot of supply; maybe 2000-5000 per year. But I do want to know this before I proceed down the road of using the Pine.
I suggest you PM or email tllim about this as he is the only person who can answer your question.
As mentioned on the PM reply, PINE64 able to supply in bulk and 2000-5000 annual volume in ease.
Thanks. That's a problem with the RPi Zero, Omega 2, and some other boards. I'm currently evaluating the CHIP Pro but if that fails I may be buying some Pines. Sure would love a lower-powered/lower-spec'd version like the Zero that can run Linux.
Omega2 is brand new. think back 1 year ago when pine64 was brand new. omega2 actually doing much better, onion is ~ 2 months off schedule. it was twice that time before pine64 started shipping in any volume. add to that onion has about ~10 new products instead of 1.
  UK power supply (Pinebook Pro 64) skobi 0 2,309 11-17-2019, 04:55 AM
Last Post: skobi
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,705 05-24-2018, 01:58 AM
Last Post: crapped
  Power supply questions montero65 36 45,858 08-15-2017, 03:51 AM
  No,Product, No reply from Feb 2 cmroberts 4 5,829 03-05-2017, 09:41 PM
Last Post: cmroberts
  Integration with E-Ink Touchscreen adamjedgar 3 5,809 02-16-2017, 04:56 AM
Last Post: adamjedgar
  Can I use Raspberry Pi3 Power supply for Pine? nizam27391 7 8,470 06-13-2016, 11:49 AM
Last Post: jonW
  How to return the product? psprinter 3 5,256 04-24-2016, 03:31 PM
Last Post: cookeys
