Long-sleep image vs Pine64 image
My Pine just arrived and I am excited to get up and running. As I perusing the Wiki, I noticed that the Pine64 folks have posted the Ubuntu image linked below. Their image is based on @longsleep's, and I have three questions about this.
#1 Do we know if the Pine image is based on the newest Longsleep release?
#2 Is the Pine64 image different from Longsleep's outside of the obvious package differences?
#3 Is there any else I should consider before choosing one image over the other?
Thank you!
http://files.pine64.org/os/ubuntu/xubunt...64-8GB.zip
Sent from my SM-T537V using Tapatalk
to answer that question I must state the obvious.
The 8gb file download is certainly not longsleep's handy work. His images are base ubuntu core and are less than 200mb in size. Some of the images being downloaded are a bit out dated even my debian builds and longsleep's builds. At this point I would liek to say how everything is tied into longsleep's work as he was th efirst to get a working Kernel with all the functional bits (ethernet,wireless,hdmi etc etc). In essence everything is driven by his kernel/uboot build (simpleimage and scripts).
The best place to get longsleep's stuff is either direct or from pine64.pro as it keeps the latest images up for download and regularly checks for functionality.
links
https://www.stdin.xyz/downloads/people/l...64-images/
https://www.pine64.pro/downloads/
keep in mind that this will soon be rectified as myself and others are working on a system to keep only the freshest and thoroughly tested images up on the wiki and official pine sites Wink.
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(05-05-2016, 08:51 PM)jl_678 Wrote: #1 Do we know if the Pine image is based on the newest Longsleep release?
  1. Will be answered if you execute the scripts from the next link. It's a shame that it's not outlined in the wiki that these scripts are essential.
  2. Yes, it's different (bloated and manipulated) and should be avoided, reasons here: http://forum.pine64.org/showthread.php?t...47#pid8547
  3. The problem with the manipulated OS images is that they ALL introduce more bugs and that they lack documentation. Most probably to trick backers into believing Linux support would be close to final (which is not, read through the honest announcement for longsleep's original Xenial image what you can expect NOW)
You can add an desktop environment of your choice to the original longsleep Xenial image and by adopting patches made for OpenELEC/H3 with longsleep's kernel and a new tool also dynamic display resolution switching will work soon.
Thank you both for your response. I have already downloaded and installed Longsleeps Ubuntu instance from here: https://www.stdin.xyz/downloads/people/l...es/ubuntu/
Given both of your feedback, it sounds like that is the right option. I had wondered with the Pine version was somehow better or at least more complete from a package standpoint. Clearly that is not true.
Wish me luck as I am testing all this out today!
Thank you,
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,674 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 8,040 01-04-2020, 10:32 AM
Last Post: igorp
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,593 02-01-2019, 05:09 AM
  Disable HDMI Pine64 Andruxa89 1 7,496 01-31-2019, 11:18 AM
Last Post: martinayotte
  Unable to run hello-world docker container on Pine64 kamtschatka 2 9,440 01-24-2019, 04:29 AM
Last Post: arboehm
  KDE on pine64? jamiechang917 6 16,406 01-14-2019, 01:47 PM
Last Post: brigmohan
  External DAC - Pine64 mjgoode 2 8,039 09-05-2018, 12:12 AM
Last Post: mjgoode
  Summer Undergraduate Research using Pine64's pkivolowitz 3 8,672 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 943,712 01-31-2018, 11:58 AM
Last Post: Luke
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 4,634 07-08-2017, 09:34 AM
Last Post: petec
